Postby gyula.borsos » 29 Nov 2017, 16:08
alsa equalizer is working?
Thanx!
gyula.borsos
Postby avvy65 » 29 Nov 2017, 18:23
If I were to install a new image , I would then have to set everything up again. That being the case I would have to write all my settings down so to put them into the new image.
avvy65
Postby janui » 30 Nov 2017, 08:58
Hi avvy65,
Yes, that is correct. But the backup / restore function in Rern's Addons should save and restore your database and settings, you could give it a try. If you upgrade the image as described (in this thread) here runeaudio-0-4-beta-for-raspberry-pi2-3-t4434-360.html#p23634 you will not lose your settings.
Postby EZJstef » 03 Dec 2017, 19:03
Ge ,
i am starting a new project for my wife, for the next Xmas..........
1° i tryied the 0.3 and 0.4 with addons plugin......and never get upload MPD corretly when i finish , i lost the runeaudio interface on my touchscreen ( but i don't lost starting or shutdown pictures screen)
2° i make more test with the 0.4 and find problem with DLNA with airaudio app , i can connect to runeaduio but after it's connect /disconnect connect etc each 3s ! but it worked good on 0.3 when i tested.....
so i will prefect keep the 0.4 should be better for me ...... but DLNA necessary for wife, bluetooth will be the best but don't find anything correct for that !
if somebody can help me to resolve the MPD update and DLNA trouble on 0.4 should be great ... Xmas arrive fast so now need help!
i hope my english is enough understood for somebody around
tnx a lot for the great job for this nice app runeaudio !!!!!!
Stef
EZJstef
Postby jlynton » 03 Dec 2017, 21:12
I only stumbled across this today, and have downloaded RuneAudio_rpi2_rp3_0.4-beta_20170229_2GB.img.gz
Is this the latest image?
jlynton
Postby hondagx35 » 03 Dec 2017, 22:17
Postby jlynton » 04 Dec 2017, 00:00
Many thanks Frank,
I look forward to trying it.
Jeremy
jlynton
Postby EZJstef » 04 Dec 2017, 06:52
Hi Jeremy,
let me know pse, how works DLNA in your side? with this image unstable here connect/disconnect all the 3s !....
tnx
stef
EZJstef
Postby ccrys » 04 Dec 2017, 10:02
I've installed Rune Audio Remote for Android and I get the message: canot find my player.
After I read the documentation I understand that I must to update or modiffy some parameters from /etc/avahi/services/runeaudio.service .
I don't how to do this because when I insert sd card with Rune Audio in laptop I can't see the partition with /etc/avahi/services, only a 100mb partition.
Raspberry Pi 2, RuneAudio 0.4-beta, Android 7.
ccrys
Postby hondagx35 » 04 Dec 2017, 12:54
