Postby hondagx35 » 06 Jan 2018, 16:51
Postby Ripa » 07 Jan 2018, 12:50
Frank,
i mean must i reset (hardware) or only replace the SD card and start up
thanks
Jempie
Ripa
Postby hondagx35 » 07 Jan 2018, 18:39
Hi Jempie,
what do you mean with "reset hardware"?
Make the changes, save and reboot.
Postby Ripa » 09 Jan 2018, 10:37
Frank,
is there a way to add an password to the main setup menu,
because my kinds always change everything in the setup
Jempie
Ripa
Postby Dimon B » 09 Jan 2018, 15:14
Hello! I use the Raspberry Pi 3 and pioneer A50DA connected via USB. RuneAudio 0.4-beta for Raspberry Pi2/3. Can't play DSD. DSD native and DoP instead of music heard a loud hiss. Please help, what could be the problem?
https://pastebin.com/UTzknni1
Dimon B
Postby janui » 09 Jan 2018, 20:06
Postby max.poluektov » 09 Jan 2018, 20:25
Great Job,
could you please include support for IQaudIO DigiAmp+? Now I can't select it as an output. Or maybe you could suggest me a solution?
Thanks in advance
max.poluektov
Postby janui » 09 Jan 2018, 20:42
Postby Ripa » 10 Jan 2018, 03:50
does anyone can help me out with the following problem
i want to use the adafruit 5 inch hdmi with touch screen display, instead of the 7 inch to build an smaller case
i only see 80% of the screen with a white and the touch screen does not work
jempie
Ripa
Postby Dimon B » 10 Jan 2018, 12:20
Hello, janui. Thanks for the quick response. I have a problem with DSD, just as in this thread raspberry-pi-3-mpd-0-19-13-dsd-t3539.html . Probably support pioneer a50da limited to Microsoft Windows. Is there a solution to this problem or is it better to refuse to play files of that type on the Raspberry Pi 3 ?
Dimon B
Users browsing this forum: No registered users and 37 guests
