Postby janui » 10 Jan 2018, 14:02
Postby Dimon B » 10 Jan 2018, 19:07
the debug file https://pastebin.com/waBT2WSR
1. DSD 64
cat /proc/asound/card?/pcm0p/sub0/hw_params
access : RW_ INTERLEAVED
format : s24_3LE
subformat : STD
channels : 2
rate : 88200 (88200/1)
period_size : 11025
buffer_size : 44100
2. DSD128
format : s24_3LE
subformat : STD
channels : 2
rate : 176400 (176400/1)
period_size : 22050
buffer_size : 88200
3. DSD256
format : s24_3LE
subformat : STD
channels : 2
rate : 352800 (352800/1)
period_size : 43691
buffer_size : 174762
In all cases, the "Noise" for DSD files.
Dimon B
Postby janui » 11 Jan 2018, 10:36
Postby sonycman » 11 Jan 2018, 10:56
Hello janui.
Would you, please, comment on my problem with erratic USB DAC recognition, which I had explained in this .
There I had to edit line 1972 of the file runeaudio.php and delete square brackets to make the script working!
Don't sure that is the right way, though...
Regards, Vlad.
sonycman
Postby janui » 11 Jan 2018, 11:58
Postby Dimon B » 11 Jan 2018, 18:26
Hi janui. Unfortunately does not work ( ‘device "plughw:0,0"’ instead of ‘device “hw:0,0”’) . It remains only to wait when will be added support for this DAC. PC + windows + JRiver works fine, so it's not a problem pioneer A50DA. Thanks for the help.
Dimon B
Postby janui » 11 Jan 2018, 22:18
Postby Ragea » 14 Jan 2018, 14:56
At first congratulation this work!
I would like to ask a small support. I made a new install, use lan connection and default setting.
But I can't connect to my Runeaudio/Raspberry 3 with Putty. (from win7)
SSH connect gave this message:unexpected SS2_ MSG_UNIPLEMENTED packet
I haven't found feedback in forum for this issue
Do you have any idea?
Ragea
Postby hondagx35 » 14 Jan 2018, 17:19
Hi Ragea,
this is not an issue with Rune.
Please check your Putty version and your Kex settings.
With the latest version (0.70) and these settings, it works like it should.
Postby Ragea » 14 Jan 2018, 18:29
Thank you!
Ragea
