Postby gearhead » 02 Mar 2018, 14:59
gearhead
Postby Ripa » 02 Mar 2018, 17:30
i want to have access to the USB drive on the Raspberry without remove the usb drive
so with the Win PC he see Runeaudio but cannot access it
the same for imac
how can i change this?
thanks
Ripa
Postby Ripa » 02 Mar 2018, 23:57
i found the solution
log in with Putty
systemctl enable smbd
systemctl start smbd
work perfect
Ripa
Postby Ripa » 05 Mar 2018, 21:22
hi,
i have use rip program dbpoweramp to rip a cd, both Flac and Aiff
use the sabre dac but no sound!!! only MP3 and does play 32 bits / 192
also stereo,f
why can i not play flac or aiff
thanks for your help
Ripa
Postby janui » 05 Mar 2018, 23:37
Hi Ripa,
There are some problems with the Sabre I2S DAC's. From your post I cannot see if you are using an I2S DAC or a USB DAC. If you are using an I2S DAC try this:
Modify the DAC type in the Settings page to RPI DAC, reboot, then reset your output type in the MPD page.
Most Sabre DACs cannot process 16bit input data streams, only 24 or 32bit. The RPI DAC driver converts all output to at least 24bit. Most of the other drivers do not need to do this as their DAC's can process 16bit data streams. This is a workaround, the RPI DAC drivers are not built for Sabre DAC's. Drivers do exist for the Sabre DAC’s, but the manufacturer refuses to make them publicly available. This makes the I2S Sabre based products much less attractive for general use.
Postby Ripa » 06 Mar 2018, 09:23
Janui,
i have this sabre dac
https://www.audiophonics.fr/en/diy-dac/ ... 11500.html
now i want to buy https://www.audiophonics.fr/en/diy-dac/ ... 12105.html
is this better, or still some problems
btw is there an dac that can play without problems any format
Ripa
Ripa
Postby Ripa » 06 Mar 2018, 09:29
Janui,
what do you maen with
the setting is now
Audio output = HiFiberry DAC i2s
Ripa
Postby Ripa » 06 Mar 2018, 09:33
Janui,
I cannot select an DAC only hifiberry dac i2s / PI analog out / Pi HDMI out
how can i change it too all different dac's
Ripa
Postby janui » 06 Mar 2018, 10:46
Postby Ripa » 06 Mar 2018, 16:13
Janui,
i have try to set it to RPI DAC, but still only distortion what can I do wrong
thx
Ripa
Users browsing this forum: Baidu [Spider] and 8 guests
