Postby Ripa » 06 Mar 2018, 16:23
the audio output is I-Sabre DAC i2s
Ripa
Postby janui » 06 Mar 2018, 17:07
Postby Ripa » 09 Mar 2018, 09:26
aif
access: RW_INTERLEAVED
format: S16_LE
subformat: STD
channels: 2
rate: 44100 (44100/1)
period_size: 4096
buffer_size: 16384
format: S16_LE
subformat: STD
channels: 2
period_size: 4410
buffer_size: 22050
flac
format: S16_LE
subformat: STD
channels: 2
period_size: 4410
buffer_size: 22050
Ripa
Postby Ripa » 09 Mar 2018, 09:49
i use DBpoweramp for ripping in the different format is this OK?
Ripa
Postby janui » 09 Mar 2018, 14:39
Postby Ripa » 10 Mar 2018, 13:57
Janui,
thanks man i will try this...
Do you have an solution for this
evert time my kids play with the Rune display an they change everything in the menu
is there a way to add an password to the menu, that way only with the password you have access to the menu
Ripa
Ripa
Postby Ripa » 11 Mar 2018, 12:31
To use RuneAudio, BubbleUPnP and Qobuz, you need an Android pad or phone, and a running RuneAudio unit with UPnP/DLNA enabled, all on the same network. On the Android, install BubbleUPnP. You may select use the free version to start with, you may want to pay for a licensed version later to get rid of the ads, plus some other limitations.
On the top left of the BuppleUPnP app there is a menu, tap on it and you will see RENDERER, LIBRARY and Settings.
Under RENDERER you should see "Local Renderer", which is you Android unit, and "RuneAudioUPnP", which is your RuneAudio player. Select "RuneAudioUPnP".
Open library "Local and Cloud", select Qobuz and enter your credentials.
Browse the Qobuz for music in main bottom right tab Library, add tracks to the middle tab Playlist, tap on an item in the playlist to play it.
This is it, really.
How can i access DLNA, its now switch off
on the settings airplay and DLNA is on but both are not available
thanks
Ripa
Postby EZJstef » 23 Mar 2018, 18:20
Hello ,
i am wonder the signification
*of the red number "2" near on the left of the icon menu on playback screen , somebody can help me??
*The lighnning symbol is power supply too low ??
Thanks Stef
EZJstef
Postby LeighP » 23 Mar 2018, 22:32
I seem to have a red 1 myself.
Weird as never appeared before.
Leigh
LeighP
Postby EZJstef » 26 Mar 2018, 06:13
Hi , i found the red number, is the number of addon can be uploaded with new version .....
Stef
EZJstef
