Postby Dave Platt » 22 May 2018, 18:47
Dave Platt
Postby janui » 22 May 2018, 22:01
Hi DavePlat,
ashuffle works fine when a more recent Linux version is installed. It's random function will then not return the same track results. Unfortunately updates to v0.4 are now very difficult. If this is important for you the image here works as it should: runeaudio-0-3-beta-for-raspberry-pi-t502-520.html#p23625
You will lose most of the 0.4 functionality.
Postby Dave Platt » 23 May 2018, 00:33
Thanks very much for the information, janui!
Since my NTP-service-based workaround seems to be effective on my system, I think I'll stick with my current lightly-modified 0.4 setup for now, and await the eventual "grand convergence" of the 0.4 features, and the more modern kernel and other backing packages that you've put in the 0.3 update.
Is there any standard repository available online for the source code for the various versions? I looked at the github repositories pointed to by this site, and they don't seem to have been updated in the last couple of years. Since there are components in RuneAudio which are under GPL, keeping current source code available for download would seem to be essential...?
Dave Platt
Postby rastus » 23 May 2018, 01:29
Hello Dave,
I am reading your few posts with keen interest. So polite too: "grand convergence" Giggles!
Regards,
Rastus.
rastus
Postby Dave Platt » 23 May 2018, 04:37
Heh... thanks! :) I know that mergers between development branches can often be a bear to manage successfully... I've seen a few which were more train-wrecks than convergences... but I'll gladly keep my fingers crossed that this one goes well.
Here are a couple of quick photos of my weekend-project player:
Part of the challenge to this, was that I wanted to make the player out of as many recycled, surplus, and out-of-my-big-junk-box-of-interesting-stuff parts as I could, with as few "new-item" purchases as possible. I could certainly have gone out and gotten a nice commercial case and kit for it, but as they say, where's the fun in that? The rest of the system I'm using it with is of the same ilk... a pair of rotted-out Minimus 77 mini-speakers that I bought for about $5, and gave a tender-loving upgrade (re-foamed the woofers, scratch-built a new Zilch crossover with decent 5-way connectors, vibration-coated the cabinets) and a Proton D940 that needed a bunch of TLC (new power switch, full cleaning of the controls, and an IF alignment). I love bringing old stuff back from Beyond.
So... anyhow, what you see is the result of my recycling and improvisation over the course of a weekend. The case is (clearly) from an old Black Box GPIB converter that I'd bought for $5 (and you can't find a nice new metal case for that sort of price). The TO-220 heatsink came off of the converter's PC board. The back panel had been mounted to the converter PC boards and was now floating loose, so I just mounted it with a couple of angle brackets and some JB Weld. The power switch, polyfuse, capacitors, and regulators came out of my junkbox (the big regulator is a Micrel high-reliablility part from a surplus buy - basically a 7805 on steroids - I measured 3 and they were all between 5.00 and 5.02 volts). The RCA jacks were a surplus buy (the yellow "video" jack is unused). Hot-melt glue was used where appropriate.
There's certainly more I could do to this... maybe some front-mounted GPIO-driven LEDs for status, and/or some switches hooked up to a script which would issue play/pause/skip/shutdown commands. I'll wait to see if inspiration strikes.
I may build another of these at some point, for the primary music system in the living room. If I do I'm sure I'll pay a lot more attention to detail and cosmetics, in addition to audiophilia. I like the idea of using a DAC with a low-jitter on-board "master" clock - running the DAC directly from a crystal has always appealed to me. Maybe use a box big enough to support a decent-sized LCD touchscreen (I got one of the 2.8" screens along with the Pi I bought, but it's really too small to be useful for control).
Dave Platt
Postby LeighP » 25 May 2018, 19:39
Looking really good Dave!
LeighP
Postby tetedecon » 10 Jun 2018, 09:48
Hi there,
Pretty sastified with Rune 0.4 Audio running on Rasp 3.
Is there any way or a setting already existing to manage playback autoswitch off?
Thanks.
tetedecon
Postby Ripa » 18 Jun 2018, 23:25
Does any can help me out with spotify, i have an premium account
how can i stream to the runeplayer?
i also need to protect the setup menu my kinds f*ck up the settings
thanks
Ripa
Postby tml3nr » 21 Jun 2018, 09:55
tml3nr
Postby Ripa » 22 Jun 2018, 12:21
tml3nr,
i will try this, i have RPI3 not 2, hope this will work
Anyone an solutions for protect the menu settings?
Ripa
Ripa
Users browsing this forum: No registered users and 48 guests
