Postby tml3nr » 28 Jun 2018, 03:08
After update from Rune 0.4_20170229 to 4.14.50-2 on RPI3. It's work fine on RPI3 B+:
rpi-3-b-t6393.html
tml3nr
Postby SimonS » 29 Jun 2018, 10:26
On RPi3 work great with integrated WiFi. On my RPi2 + Cisco WiFi dongle not find wifi network. With old version of 0.4 work great.
Debug code
https://pastebin.com/3FCqTUCa
SimonS
Postby hondagx35 » 29 Jun 2018, 15:33
Postby SimonS » 29 Jun 2018, 16:51
Point is that at previus relase work. I try 2.times to use last and 2.times old version
WLAN was found, but remain in searching...
Also with RPi3 work well so I think that with wifi is everything OK.
SimonS
Postby Ripa » 02 Aug 2018, 21:38
i have the following problem;
RPI-3 use rune setting the network to WLan and ETHO
if connected with ethernet cable Bubble Upnp works perfect i see Rune in Renderer
if i disconnect the ETHO cable there is still an Wlan network i can not see the Rune player in Renderer
how can i solve this problem
thanks
Ripa
Postby Ripa » 10 Aug 2018, 08:09
Does anyone know why spotify works perfect with iphone but not with android
Ripa
Postby HansRune » 15 Aug 2018, 18:27
After using Volumio for a long time I discovered problems when using the official Raspberry 7" touchscreen so I decided to test Rune Audio and it looks great. Boots much faster, has a virtual keyboard, hides the mousecursor and even the touchscreen works out-of-the box with the latest beta. Unfortunately I have (as a Rune newbie) a problem and I could not found a solution within the many pages on this board.
From time to time, after booting (via the menu or by powering off and on), the GUI works as usual and I can select a source but the music does not play and the songtimer does not run. So far I can solve it by booting one or more times but the issue looks random. I'll link to two debug files, one when all works fine and the other when the issue occurs. Doe someone know what is wrong?
My system: RPi3b/ HiFiBerry Dac+ / official Raspberry 7" touchscreen / board power 5.05 volt.
Debug with problem:
Debug without problem:
HansRune
Postby hondagx35 » 15 Aug 2018, 19:51
Hi HansRune,
I checked your debug files and couldn't find anything obvious.
Where is your music stored? I can not see any mounts (network or USB) in both files.
Postby HansRune » 15 Aug 2018, 20:12
Thanks for checking! The logs were created with only two radiostations added to Rune Audio but when I connect a USB drive (fast SD-card) the same problem occurs. Using Volumio there also were, more serious, booting issues after installing the Raspberry 7" touchscreen. So I wonder if the display is causing the problem.
Regards, Hans.
HansRune
Postby HansRune » 16 Aug 2018, 18:54
Sorry to say but still the same problem, the problem stays the same when using another RPi with another SD card.I have done a fresh install of the beta, added four radiostations and did not mount any USB drive. Powered with 5 amp and 5.12 volt on the board, the network connections are okay. After correct playing for hours, including some hard- and soft reboots, the player stopped working after the last boot.
The GUI is still working correct and I can use all menu functions from the touchscreen and from my browser. But no audio after selecting one of the radiostreams. No error messages only the tracktimer does not run and no audio. Do you have suggestions? Below a new debug file on Pastbin, generated after an unsuccessfull reboots a few minutes ago.
Best regards, Hans.
The GUI looks okay but no timer and no audio.
HansRune
