Postby Dimon B » 05 Dec 2018, 10:54
Hello! I chose Raspberry Pi DAC in the settings. Aoid dac II is defined as" I-Sabre DAC (I2S)". Perform poorly. When switching tracks there is a click. When playing DSD files noise instead of music. There's no problem with Volumio, but I like RuneAudio. Is there a possibility of normal operation of this DAC C RuneAudio 0.4 and Raspberry Pi 3B ? Thank you!
Dimon B
Postby janui » 06 Dec 2018, 15:55
Postby looper » 10 Dec 2019, 10:39
I'm having trouble adding https radio streams to my RaspberryPi2, the normal http ones work ok, but many changed to the secure version and it seems that Rune doesn't recognize them.
Can this be solved somehow?
looper
Postby MusicLover22 » 11 Jan 2020, 01:36
Just testing this release and this is by far the best working runeaudio release so far, i'm surprised that the almost a year newer version is really broken compared to this one, this one operates pretty perfectly on my pi 3+, thanks!
MusicLover22
Auto Mounting of external USB drive as Read Only
Postby Nudge » 04 Mar 2020, 20:30
I'm trying to set a trigger on Rune 0.4b that changes a USB external drive to be Read Only when mounted.
The following does not appear to work on Rune 0.4b using Arch Linux although it does on other flavours of Linux.
/etc/udev/rules.d/96-enforce-usb-ro.rules: (also tried: /usr/lib/udev/rules.d/96-enforce-usb-ro.rules)
SUBSYSTEMS=="usb", ACTION=="add", KERNEL=="sd*", ENV{SYSTEMD_WANTS}="enforce-usb-ro@%k"
/lib/systemd/system/enforce-usb-ro@.service:
[Unit]
Description=Enforce read-only mode on USB storage device
BindsTo=dev-%i.device
[Service]
Type=simple
ExecStart=/usr/bin/mount -o remount,ro /dev/%I
I'm obviously missing something and cannot determine the Arch Linux automount rule which might be a better place to mount as Read Only (I have a sneaky suspicion that devmon may be involved somewhere).
Any pointers / examples gratefully received !
Nudge
Postby Spiralgalaxy5 » 09 May 2020, 20:26
Spiralgalaxy5
Postby hondagx35 » 13 May 2020, 11:06
Postby Spiralgalaxy5 » 16 May 2020, 21:11
>It should be fixed with 0.4
It'll be interesting to try it out. Thanks for getting back to me.
Tim
Spiralgalaxy5
Postby Spiralgalaxy5 » 23 Jun 2020, 21:21
Midori CPU% on Webradios
Spiralgalaxy5
Postby dhanushx012 » 06 Sep 2020, 12:01
I've read elsewhere that the recent versions of MPD can play .M3U8 files natively (as used by the BBC now for their highest-res feeds). It would be great to have this in Rune. (rather than have to use MinimServer).
dhanushx012
