Postby dhanushx012 » 08 Dec 2020, 11:45
Thanks for checking! The logs were created with only two radiostations added to Rune Audio but when I connect a USB drive (fast SD-card) the same problem occurs. Using Volumio there also were, more serious, booting issues after installing the Raspberry 7" touchscreen. So I wonder if the display is causing the problem.
dhanushx012
Postby SpecialK » 08 Mar 2023, 10:37
Hello everyone,
Just trying to get Rune up and running and I can not seem to find the link to DL the software needed to run Allo Bos Dac of PI. The one posted in 2014 does not seem to unzip either.
Thank you in advance
SpecialK
Postby arnaldo » 23 Apr 2023, 12:57
Hello everyone,
i have raspberry pi3 release version: 0.4 (build: beta-20141216)
now sold my PS Audio DAC i use a dragonfly black but is not detected!
please help me that's my debug
###### System info ######
Linux version 4.14.39-1-ARCH (builduser@leming) (gcc version 7.3.1 20180406 (GCC)) #1 SMP Sat May 5 19:22:41 UTC 2018
system time: Mon Feb 22 15:40:26 CET 2016
system load: 0.73 0.16 0.05 1/134 708
HW platform: unknown (--)
playerID: --da712d152cb6ec3a33c300d9e053d71f
###### System load statistics (procinfo -H) ######
Memory: Total Used Free Buffers
RAM: 935.92MiB 156.00MiB 779.93MiB 14.52MiB
Swap: 0.00B 0.00B 0.00B
Bootup: Mon Feb 22 15:40:09 2016 Load average: 0.73 0.16 0.05 2/136 710
user : 00:00:05.62 9.0% page in : 147017
nice : 00:00:01.26 2.0% page out: 472
system: 00:00:07.26 11.6% page act: 10323
IOwait: 00:00:08.77 14.0% page dea: 0
hw irq: 00:00:00.00 0.0% page flt: 117534
sw irq: 00:00:00.18 0.3% swap in : 0
idle : 00:00:39.54 63.1% swap out: 0
uptime: 00:00:16.52 context : 73939
irq 16: 0 irq 54: 2163
irq 17: 6384 irq 55: 0
irq 21: 0 irq 56: 0
irq 23: 42 irq 59: 0
irq 24: 2 irq 62: 26618
irq 46: 0 irq 83: 2
irq 48: 0 irq 86: 50
irq 50: 0 irq 92: 7297
irq 51: 17
mmcblk0 2183r mmcblk0p2 2113r
mmcblk0p1 59r sda 1079r 0w
eth0 TX 962.00B RX 773.00B wlan0 TX 0.00B RX 0.00B
lo TX 160.65KiB RX 160.65KiB
###### Active processes (pstree) ######
systemd-+-agetty
|-avahi-daemon---avahi-daemon
|-cmd_async---sh---debug_collector---sh---pstree
|-dbus-daemon
|-devmon---udevil
|-ifplugd---netctl.action---network---dhcpcd
|-mount.ntfs
|-mpd-+-{decoder}
| |-{io}
| |-{mpd}
| |-{output:default }
| `-{player}
|-nginx---nginx
|-nmbd
|-ntpd---{ntpd}
|-php-fpm---3*[php-fpm]
|-redis-server---2*[{redis-server}]
|-rune_PL_wrk
|-rune_SY_wrk
|-sh---sleep
|-sshd
|-systemd-journal
|-systemd-resolve
|-systemd-udevd
`-wpa_supplicant
###### Audio backend ######
Advanced Linux Sound Architecture Driver Version k4.14.39-1-ARCH.
0 [v15 ]: USB-Audio - AudioQuest DragonFly Black v1.5
AudioQuest AudioQuest DragonFly Black v1.5 at usb-3f980000.usb-1.4, full speed
PLAYBACK devices: (aplay -l)
card 0: v15 [AudioQuest DragonFly Black v1.5], device 0: USB Audio [USB Audio]
Subdevices: 1/1
Subdevice #0: subdevice #0
PCM devices: (aplay -L)
null
default:CARD=v15
AudioQuest DragonFly Black v1.5, USB Audio
Default Audio Device
sysdefault:CARD=v15
front:CARD=v15,DEV=0
Front speakers
surround21:CARD=v15,DEV=0
2.1 Surround output to Front and Subwoofer speakers
surround40:CARD=v15,DEV=0
4.0 Surround output to Front and Rear speakers
surround41:CARD=v15,DEV=0
4.1 Surround output to Front, Rear and Subwoofer speakers
surround50:CARD=v15,DEV=0
5.0 Surround output to Front, Center and Rear speakers
surround51:CARD=v15,DEV=0
5.1 Surround output to Front, Center, Rear and Subwoofer speakers
surround71:CARD=v15,DEV=0
7.1 Surround output to Front, Center, Side, Rear and Woofer speakers
iec958:CARD=v15,DEV=0
IEC958 (S/PDIF) Digital Audio Output
card 0:
Simple mixer control 'PCM',0
card 0:
numid=2,iface=MIXER,name='PCM Playback Switch'
numid=3,iface=MIXER,name='PCM Playback Volume'
numid=1,iface=PCM,name='Playback Channel Map'
Output 1 (default detected output) is enabled
###### mpd version ######
mpd version: 0.19.0
###### mpd.conf ######
log_level "verbose"
log_file "/var/log/runeaudio/mpd.log"
state_file "/var/lib/mpd/mpdstate"
zeroconf_enabled "yes"
zeroconf_name "runeaudio"
bind_to_address "/run/mpd.sock"
bind_to_address "any"
port "6600"
max_connections "20"
user "mpd"
group "audio"
db_file "/var/lib/mpd/mpd.db"
sticker_file "/var/lib/mpd/sticker.sql"
pid_file "/var/run/mpd/pid"
music_directory "/mnt/MPD"
follow_outside_symlinks "yes"
follow_inside_symlinks "yes"
auto_update "yes"
filesystem_charset "UTF-8"
id3v1_encoding "UTF-8"
volume_normalization "no"
audio_buffer_size "2048"
buffer_before_play "10%"
gapless_mp3_playback "yes"
mixer_type "disabled"
input {
plugin "curl"
decoder {
plugin "ffmpeg"
enabled "yes"
replaygain "off"
hardware platform: unknown
current orionprofile: RuneAudio
kernel scheduler for mmcblk0: [noop] deadline cfq
/proc/sys/vm/swappiness: 0
/proc/sys/kernel/sched_latency_ns: 18000000
/proc/sys/kernel/sched_rt_period_us: 1000000
/proc/sys/kernel/sched_rt_runtime_us: 950000
/proc/sys/kernel/sched_autogroup_enabled: 1
/proc/sys/kernel/sched_rr_timeslice_ms: 100
/proc/sys/kernel/sched_min_granularity_ns: 2250000
/proc/sys/kernel/sched_wakeup_granularity_ns: 3000000
Module = "snd_usb_audio"
Attributes:
coresize = "159744"
initsize = "0"
initstate = "live"
refcnt = "0"
taint = ""
uevent =
Parameters:
autoclock = "Y"
device_setup = "0,0,0,0,0,0,0,0"
enable = "Y,Y,Y,Y,Y,Y,Y,Y"
id = "(null),(null),(null),(null),(null),(null),(null),(null)"
ignore_ctl_error = "N"
index = "-1,-1,-1,-1,-1,-1,-1,-1"
pid = "-1,-1,-1,-1,-1,-1,-1,-1"
quirk_alias = "(null),(null),(null),(null),(null),(null),(null),(null)"
vid = "-1,-1,-1,-1,-1,-1,-1,-1"
Sections:
.ARM.exidx = "0x7f47e9d4"
.ARM.exidx.exit.text= "0x7f47bce0"
.ARM.exidx.init.text= "0x7f47bcd8"
.alt.smp.init = "0x7f47e9cc"
.bss = "0x7f481d80"
.data = "0x7f480000"
.exit.text = "0x7f476228"
.gnu.linkonce.this_module= "0x7f481b80"
.init.text = "0x7f48d000"
.note.gnu.build-id = "0x7f477000"
.rodata = "0x7f477028"
.rodata.str1.4 = "0x7f47bce8"
.strtab = "0x7f4944a0"
.symtab = "0x7f48e000"
.text = "0x7f465000"
__param = "0x7f47e918"
###### Systemd active startup scripts (ls -lah /etc/systemd/system/multi-user.target.wants/) ######
total 8.0K
drwxr-xr-x 2 root root 4.0K Feb 22 2016 .
drwxr-xr-x 6 root root 4.0K Mar 13 2016 ..
lrwxrwxrwx 1 root root 44 Feb 15 2015 avahi-daemon.service -> /usr/lib/systemd/system/avahi-daemon.service
lrwxrwxrwx 1 root root 39 Feb 8 2015 haveged.service -> /usr/lib/systemd/system/haveged.service
lrwxrwxrwx 1 root root 44 Mar 11 2016 mpd-watchdog.service -> /usr/lib/systemd/system/mpd-watchdog.service
lrwxrwxrwx 1 root root 44 Mar 21 2016 netctl-auto@wlan0.service -> /usr/lib/systemd/system/netctl-auto@.service
lrwxrwxrwx 1 root root 47 Feb 22 2016 netctl-ifplugd@eth0.service -> /usr/lib/systemd/system/netctl-ifplugd@.service
lrwxrwxrwx 1 root root 37 Feb 14 2015 nginx.service -> /usr/lib/systemd/system/nginx.service
lrwxrwxrwx 1 root root 36 Feb 15 2015 ntpd.service -> /usr/lib/systemd/system/ntpd.service
lrwxrwxrwx 1 root root 39 Feb 14 2015 php-fpm.service -> /usr/lib/systemd/system/php-fpm.service
lrwxrwxrwx 1 root root 37 Feb 14 2015 redis.service -> /usr/lib/systemd/system/redis.service
lrwxrwxrwx 1 root root 40 Mar 19 2016 remote-fs.target -> /usr/lib/systemd/system/remote-fs.target
lrwxrwxrwx 1 root root 43 Feb 14 2015 rune_PL_wrk.service -> /usr/lib/systemd/system/rune_PL_wrk.service
lrwxrwxrwx 1 root root 45 Feb 14 2015 rune_shutdown.service -> /usr/lib/systemd/system/rune_shutdown.service
lrwxrwxrwx 1 root root 43 Feb 14 2015 rune_SY_wrk.service -> /usr/lib/systemd/system/rune_SY_wrk.service
lrwxrwxrwx 1 root root 36 Feb 8 2015 sshd.service -> /usr/lib/systemd/system/sshd.service
lrwxrwxrwx 1 root root 48 Feb 8 2015 systemd-resolved.service -> /usr/lib/systemd/system/systemd-resolved.service
/dev/root / ext4 rw,relatime,stripe=32679,data=ordered 0 0
devtmpfs /dev devtmpfs rw,relatime,size=474584k,nr_inodes=118646,mode=755 0 0
devpts /dev/pts devpts rw,nosuid,noexec,relatime,gid=5,mode=620,ptmxmode=000 0 0
tmpfs /sys/fs/cgroup tmpfs ro,nosuid,nodev,noexec,mode=755 0 0
cgroup /sys/fs/cgroup/cpu,cpuacct cgroup rw,nosuid,nodev,noexec,relatime,cpu,cpuacct 0 0
cgroup /sys/fs/cgroup/pids cgroup rw,nosuid,nodev,noexec,relatime,pids 0 0
cgroup /sys/fs/cgroup/net_cls,net_prio cgroup rw,nosuid,nodev,noexec,relatime,net_cls,net_prio 0 0
systemd-1 /proc/sys/fs/binfmt_misc autofs rw,relatime,fd=25,pgrp=1,timeout=0,minproto=5,maxproto=5,direct,pipe_ino=2332 0 0
tmpfs /tmp tmpfs rw 0 0
logs /var/log tmpfs rw,nosuid,nodev,noatime,size=5120k 0 0
rune-logs /var/log/runeaudio tmpfs rw,nosuid,nodev,noatime,size=5120k 0 0
/dev/mmcblk0p1 /boot vfat rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro 0 0
fusectl /sys/fs/fuse/connections fusectl rw,relatime 0 0
/dev/sda1 /mnt/MPD/USB/Musica fuseblk rw,nosuid,nodev,noexec,noatime,user_id=0,group_id=0,default_permissions,allow_other,blksize=4096 0 0
###### Filesystem mounts - free space (df -h) ######
/dev/root 15G 1.9G 12G 14% /
devtmpfs 464M 0 464M 0% /dev
tmpfs 468M 0 468M 0% /dev/shm
tmpfs 468M 6.2M 462M 2% /run
tmpfs 468M 0 468M 0% /sys/fs/cgroup
tmpfs 468M 0 468M 0% /tmp
logs 5.0M 12K 5.0M 1% /var/log
rune-logs 5.0M 40K 5.0M 1% /var/log/runeaudio
/dev/mmcblk0p1 100M 22M 79M 22% /boot
/dev/sda1 1.9T 759G 1.1T 41% /mnt/MPD/USB/Musica
###### Loaded kernel modules ######
Module Size Used by
fuse 102400 3
snd_usb_audio 159744 0
snd_hwdep 16384 1 snd_usb_audio
snd_usbmidi_lib 28672 1 snd_usb_audio
snd_rawmidi 32768 1 snd_usbmidi_lib
snd_seq_device 16384 1 snd_rawmidi
brcmfmac 217088 0
brcmutil 16384 1 brcmfmac
cfg80211 577536 1 brcmfmac
snd_soc_wm8804_i2c 16384 0
snd_soc_wm8804 16384 1 snd_soc_wm8804_i2c
snd_soc_bcm2835_i2s 16384 0
snd_soc_hifiberry_digi 16384 0
snd_soc_core 176128 3 snd_soc_wm8804,snd_soc_bcm2835_i2s,snd_soc_hifiberry_digi
i2c_bcm2835 16384 0
snd_compress 20480 1 snd_soc_core
bcm2835_rng 16384 0
rng_core 16384 1 bcm2835_rng
snd_pcm_dmaengine 16384 1 snd_soc_core
uio_pdrv_genirq 16384 0
fixed 16384 0
uio 16384 1 uio_pdrv_genirq
sch_fq_codel 20480 3
snd_bcm2835 32768 0
snd_pcm 94208 6 snd_soc_wm8804,snd_usb_audio,snd_pcm_dmaengine,snd_soc_bcm2835_i2s,snd_bcm2835,snd_soc_core
snd_timer 32768 1 snd_pcm
snd 65536 10 snd_compress,snd_hwdep,snd_usb_audio,snd_timer,snd_rawmidi,snd_usbmidi_lib,snd_seq_device,snd_bcm2835,snd_soc_core,snd_pcm
ip_tables 24576 0
x_tables 28672 1 ip_tables
ipv6 438272 0
###### Network listening sockets (netstat -lnp) ######
Active Internet connections (only servers)
Proto Recv-Q Send-Q Local Address Foreign Address State PID/Program name
tcp 0 0 0.0.0.0:6600 0.0.0.0:* LISTEN 394/mpd
tcp 0 0 127.0.0.1:6379 0.0.0.0:* LISTEN 283/redis-server 12
tcp 0 0 0.0.0.0:5355 0.0.0.0:* LISTEN 279/systemd-resolve
tcp 0 0 0.0.0.0:80 0.0.0.0:* LISTEN 292/nginx: master p
tcp 0 0 0.0.0.0:81 0.0.0.0:* LISTEN 292/nginx: master p
tcp 0 0 0.0.0.0:82 0.0.0.0:* LISTEN 292/nginx: master p
tcp 0 0 0.0.0.0:22 0.0.0.0:* LISTEN 275/sshd
udp 0 0 0.0.0.0:68 0.0.0.0:* 357/dhcpcd
udp 0 0 0.0.0.0:36966 0.0.0.0:* 246/avahi-daemon: r
udp 0 0 127.0.0.1:123 0.0.0.0:* 286/ntpd
udp 0 0 0.0.0.0:123 0.0.0.0:* 286/ntpd
udp 0 0 0.0.0.0:137 0.0.0.0:* 339/nmbd
udp 0 0 0.0.0.0:138 0.0.0.0:* 339/nmbd
udp 0 0 0.0.0.0:5353 0.0.0.0:* 246/avahi-daemon: r
udp 0 0 0.0.0.0:5355 0.0.0.0:* 279/systemd-resolve
Active UNIX domain sockets (only servers)
Proto RefCnt Flags Type State I-Node PID/Program name Path
unix 2 [ ACC ] STREAM LISTENING 15364 283/redis-server 12 /tmp/redis.sock
unix 2 [ ACC ] STREAM LISTENING 2315 1/init /run/systemd/private
unix 2 [ ACC ] SEQPACKET LISTENING 2323 1/init /run/udev/control
unix 2 [ ACC ] SEQPACKET LISTENING 2326 1/init /run/systemd/coredump
unix 2 [ ACC ] STREAM LISTENING 3871 1/init /run/dbus/system_bus_socket
unix 2 [ ACC ] STREAM LISTENING 3874 1/init /var/run/rpcbind.sock
unix 2 [ ACC ] STREAM LISTENING 2337 1/init /run/systemd/journal/stdout
unix 2 [ ACC ] STREAM LISTENING 3876 1/init /var/run/avahi-daemon/socket
unix 2 [ ACC ] STREAM LISTENING 16016 435/php-fpm: master /var/run/php-display.sock
unix 2 [ ACC ] STREAM LISTENING 16019 435/php-fpm: master /var/run/php-db.sock
unix 2 [ ACC ] STREAM LISTENING 16022 435/php-fpm: master /var/run/php-command.sock
unix 2 [ ACC ] STREAM LISTENING 16594 394/mpd /run/mpd.sock
###### Network established sockets (netstat -np) ######
Active Internet connections (w/o servers)
tcp 0 0 127.0.0.1:54176 127.0.0.1:6379 TIME_WAIT -
Active UNIX domain sockets (w/o servers)
unix 3 [ ] DGRAM 2313 1/init /run/systemd/notify
unix 2 [ ] DGRAM 13333 271/wpa_supplicant /run/wpa_supplicant/p2p-dev-wlan0
unix 5 [ ] DGRAM 2340 1/init /run/systemd/journal/socket
unix 6 [ ] DGRAM 2362 1/init /run/systemd/journal/dev-log
unix 2 [ ] DGRAM 2644 271/wpa_supplicant /run/wpa_supplicant/wlan0
unix 2 [ ] DGRAM 13606 339/nmbd /var/lib/samba/private/msg.sock/339
unix 3 [ ] STREAM CONNECTED 14346 292/nginx: master p
unix 3 [ ] STREAM CONNECTED 2614 232/dbus-daemon /run/dbus/system_bus_socket
unix 3 [ ] STREAM CONNECTED 13819 394/mpd
unix 3 [ ] STREAM CONNECTED 3888 1/init
unix 2 [ ] DGRAM 14971 1/init
unix 3 [ ] STREAM CONNECTED 3573 177/systemd-udevd
unix 3 [ ] STREAM CONNECTED 2465 1/init /run/systemd/journal/stdout
unix 3 [ ] STREAM CONNECTED 16369 394/mpd /run/mpd.sock
unix 3 [ ] STREAM CONNECTED 14119 303/php
unix 3 [ ] STREAM CONNECTED 14739 447/php
unix 3 [ ] STREAM CONNECTED 12081 232/dbus-daemon
unix 3 [ ] STREAM CONNECTED 14022 283/redis-server 12 /tmp/redis.sock
unix 3 [ ] STREAM CONNECTED 2660 1/init /run/systemd/journal/stdout
unix 3 [ ] STREAM CONNECTED 16861 274/php
unix 3 [ ] STREAM CONNECTED 2603 1/init /run/systemd/journal/stdout
unix 3 [ ] STREAM CONNECTED 16878 283/redis-server 12 /tmp/redis.sock
unix 3 [ ] STREAM CONNECTED 13510 1/init /run/systemd/journal/stdout
unix 3 [ ] STREAM CONNECTED 16863 274/php
unix 3 [ ] STREAM CONNECTED 2809 303/php
unix 3 [ ] STREAM CONNECTED 12170 1/init /run/systemd/journal/stdout
unix 3 [ ] STREAM CONNECTED 13798 283/redis-server 12 /tmp/redis.sock
unix 3 [ ] STREAM CONNECTED 14091 702/php
unix 3 [ ] STREAM CONNECTED 14120 283/redis-server 12 /tmp/redis.sock
unix 3 [ ] STREAM CONNECTED 3971 274/php
unix 3 [ ] STREAM CONNECTED 12276 279/systemd-resolve
unix 2 [ ] DGRAM 14337 286/ntpd
unix 3 [ ] STREAM CONNECTED 2742 286/ntpd
unix 3 [ ] STREAM CONNECTED 2741 286/ntpd
unix 2 [ ] DGRAM 13999 687/mount.ntfs
unix 3 [ ] STREAM CONNECTED 14347 292/nginx: master p
unix 2 [ ] DGRAM 11717 177/systemd-udevd
unix 3 [ ] DGRAM 11723 177/systemd-udevd
unix 3 [ ] STREAM CONNECTED 14742 232/dbus-daemon /run/dbus/system_bus_socket
unix 3 [ ] DGRAM 11722 177/systemd-udevd
unix 3 [ ] STREAM CONNECTED 2600 1/init /run/systemd/journal/stdout
unix 3 [ ] STREAM CONNECTED 15763 399/bash
unix 3 [ ] STREAM CONNECTED 13716 1/init /run/systemd/journal/stdout
unix 3 [ ] STREAM CONNECTED 13146 229/ifplugd
unix 3 [ ] STREAM CONNECTED 13392 275/sshd
unix 3 [ ] STREAM CONNECTED 12172 1/init /run/systemd/journal/stdout
unix 3 [ ] STREAM CONNECTED 4092 279/systemd-resolve
unix 3 [ ] STREAM CONNECTED 13470 232/dbus-daemon /run/dbus/system_bus_socket
unix 2 [ ] DGRAM 628 151/systemd-journal
unix 2 [ ] DGRAM 4086 279/systemd-resolve
unix 3 [ ] STREAM CONNECTED 16000 435/php-fpm: master
unix 3 [ ] STREAM CONNECTED 13191 231/sh
unix 2 [ ] DGRAM 15620 357/dhcpcd
unix 3 [ ] STREAM CONNECTED 12282 1/init /run/systemd/journal/stdout
unix 3 [ ] STREAM CONNECTED 14692 1/init /run/systemd/journal/stdout
unix 3 [ ] STREAM CONNECTED 16015 435/php-fpm: master
unix 3 [ ] STREAM CONNECTED 16014 435/php-fpm: master
unix 3 [ ] STREAM CONNECTED 15437 292/nginx: master p
unix 3 [ ] STREAM CONNECTED 2591 1/init /run/systemd/journal/stdout
unix 3 [ ] STREAM CONNECTED 15436 292/nginx: master p
unix 3 [ ] STREAM CONNECTED 13252 246/avahi-daemon: r
unix 3 [ ] STREAM CONNECTED 2615 1/init /run/systemd/journal/stdout
unix 3 [ ] STREAM CONNECTED 13457 283/redis-server 12
unix 3 [ ] STREAM CONNECTED 2627 249/avahi-daemon: c
unix 3 [ ] STREAM CONNECTED 2626 246/avahi-daemon: r
unix 3 [ ] STREAM CONNECTED 2613 232/dbus-daemon
unix 3 [ ] STREAM CONNECTED 2631 246/avahi-daemon: r
unix 3 [ ] STREAM CONNECTED 12151 232/dbus-daemon /run/dbus/system_bus_socket
unix 3 [ ] STREAM CONNECTED 2612 232/dbus-daemon
unix 2 [ ] DGRAM 2623 246/avahi-daemon: r
###### Network interfaces (ip addr) ######
1: lo: mtu 65536 qdisc noqueue state UNKNOWN group default qlen 1000
link/loopback 00:00:00:00:00:00 brd 00:00:00:00:00:00
inet 127.0.0.1/8 scope host lo
valid_lft forever preferred_lft forever
2: eth0: mtu 1500 qdisc fq_codel state UP group default qlen 1000
link/ether b8:27:eb:d4:7e:41 brd ff:ff:ff:ff:ff:ff
3: wlan0: mtu 1500 qdisc fq_codel state DOWN group default qlen 1000
link/ether b8:27:eb:81:2b:14 brd ff:ff:ff:ff:ff:ff
###### Network interfaces (ifconfig) ######
eth0: flags=4163 mtu 1500
ether b8:27:eb:d4:7e:41 txqueuelen 1000 (Ethernet)
RX packets 4 bytes 773 (773.0 B)
RX errors 0 dropped 0 overruns 0 frame 0
TX packets 5 bytes 962 (962.0 B)
TX errors 0 dropped 0 overruns 0 carrier 0 collisions 0
lo: flags=73 mtu 65536
inet 127.0.0.1 netmask 255.0.0.0
loop txqueuelen 1000 (Local Loopback)
RX packets 3771 bytes 178812 (174.6 KiB)
TX packets 3771 bytes 178812 (174.6 KiB)
wlan0: flags=4099 mtu 1500
ether b8:27:eb:81:2b:14 txqueuelen 1000 (Ethernet)
RX packets 0 bytes 0 (0.0 B)
TX packets 0 bytes 0 (0.0 B)
###### Network netctl profiles (netctl list) ######
eth0
eth0 netctl status
netctl@eth0.service - Networking for netctl profile eth0
Loaded: loaded (/usr/lib/systemd/system/netctl@.service; static; vendor preset: disabled)
Active: inactive (dead)
Docs: man:netctl.profile(5)
eth0 netctl profile
Description='eth0 connection'
Interface=eth0
ForceConnect=yes
SkipNoCarrier=yes
Connection=ethernet
IP=dhcp
###### Network wifi status (iwconfig) ######
eth0 no wireless extensions.
lo no wireless extensions.
wlan0 IEEE 802.11 ESSID:off/any
Mode:Managed Access Point: Not-Associated Tx-Power=31 dBm
Retry short limit:7 RTS thr:off Fragment thr:off
Encryption key:off
Power Management:off
###### Kernel status (dmesg) ######
[ 0.000000] Booting Linux on physical CPU 0x0
[ 0.000000] Linux version 4.14.39-1-ARCH (builduser@leming) (gcc version 7.3.1 20180406 (GCC)) #1 SMP Sat May 5 19:22:41 UTC 2018
[ 0.000000] CPU: ARMv7 Processor [410fd034] revision 4 (ARMv7), cr=10c5383d
[ 0.000000] CPU: div instructions available: patching division code
[ 0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache
[ 0.000000] OF: fdt: Machine model: Raspberry Pi 3 Model B Rev 1.2
[ 0.000000] Memory policy: Data cache writealloc
[ 0.000000] cma: Reserved 8 MiB at 0x3b800000
[ 0.000000] On node 0 totalpages: 245760
[ 0.000000] free_area_init_node: node 0, pgdat 80f9c340, node_mem_map baf86000
[ 0.000000] Normal zone: 2160 pages used for memmap
[ 0.000000] Normal zone: 0 pages reserved
[ 0.000000] Normal zone: 245760 pages, LIFO batch:31
[ 0.000000] random: get_random_bytes called from start_kernel+0x84/0x418 with crng_init=0
[ 0.000000] percpu: Embedded 17 pages/cpu @baf2f000 s39564 r8192 d21876 u69632
[ 0.000000] pcpu-alloc: s39564 r8192 d21876 u69632 alloc=17*4096
[ 0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
[ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 243600
[ 0.000000] Kernel command line: 8250.nr_uarts=0 bcm2708_fb.fbwidth=656 bcm2708_fb.fbheight=416 bcm2708_fb.fbswap=1 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000 root=/dev/mmcblk0p2 rw rootwait rootfstype=ext4 console=ttyS0,115200 console=tty1 selinux=0 plymouth.enable=0 smsc95xx.turbo_mode=N dwc_otg.lpm_enable=0 dwc_otg.fiq_enable=1 dwc_otg.fiq_fsm_enable=1 dwc_otg.fiq_fsm_mask=0x3 kgdboc=ttyS0,115200 elevator=noop ipv6.disable=1 quiet
[ 0.000000] PID hash table entries: 4096 (order: 2, 16384 bytes)
[ 0.000000] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes)
[ 0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes)
[ 0.000000] Memory: 949168K/983040K available (10240K kernel code, 696K rwdata, 2640K rodata, 1024K init, 745K bss, 25680K reserved, 8192K cma-reserved)
[ 0.000000] Virtual kernel memory layout:
vector : 0xffff0000 - 0xffff1000 ( 4 kB)
fixmap : 0xffc00000 - 0xfff00000 (3072 kB)
vmalloc : 0xbc800000 - 0xff800000 (1072 MB)
lowmem : 0x80000000 - 0xbc000000 ( 960 MB)
modules : 0x7f000000 - 0x80000000 ( 16 MB)
.text : 0x80008000 - 0x80b00000 (11232 kB)
.init : 0x80e00000 - 0x80f00000 (1024 kB)
.data : 0x80f00000 - 0x80fae1bc ( 697 kB)
.bss : 0x80fb8ee0 - 0x810736d4 ( 746 kB)
[ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
[ 0.000000] Hierarchical RCU implementation.
[ 0.000000] NR_IRQS: 16, nr_irqs: 16, preallocated irqs: 16
[ 0.000000] arch_timer: cp15 timer(s) running at 19.20MHz (phys).
[ 0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x46d987e47, max_idle_ns: 440795202767 ns
[ 0.000004] sched_clock: 56 bits at 19MHz, resolution 52ns, wraps every 4398046511078ns
[ 0.000009] Switching to timer-based delay loop, resolution 52ns
[ 0.000137] Console: colour dummy device 80x30
[ 0.000146] console [tty1] enabled
[ 0.000158] Calibrating delay loop (skipped), value calculated using timer frequency.. 38.40 BogoMIPS (lpj=192000)
[ 0.000166] pid_max: default: 32768 minimum: 301
[ 0.000324] Mount-cache hash table entries: 2048 (order: 1, 8192 bytes)
[ 0.000332] Mountpoint-cache hash table entries: 2048 (order: 1, 8192 bytes)
[ 0.000881] Disabling memory control group subsystem
[ 0.000931] CPU: Testing write buffer coherency: ok
[ 0.001161] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
[ 0.001365] Setting up static identity map for 0x100000 - 0x100054
[ 0.001427] Hierarchical SRCU implementation.
[ 0.001749] smp: Bringing up secondary CPUs ...
[ 0.002156] CPU1: thread -1, cpu 1, socket 0, mpidr 80000001
[ 0.002578] CPU2: thread -1, cpu 2, socket 0, mpidr 80000002
[ 0.002972] CPU3: thread -1, cpu 3, socket 0, mpidr 80000003
[ 0.003018] smp: Brought up 1 node, 4 CPUs
[ 0.003023] SMP: Total of 4 processors activated (153.60 BogoMIPS).
[ 0.003025] CPU: All CPU(s) started in HYP mode.
[ 0.003027] CPU: Virtualization extensions available.
[ 0.003508] devtmpfs: initialized
[ 0.008494] VFP support v0.3: implementor 41 architecture 3 part 40 variant 3 rev 4
[ 0.008622] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
[ 0.008631] futex hash table entries: 1024 (order: 4, 65536 bytes)
[ 0.008900] xor: measuring software checksum speed
[ 0.100005] arm4regs : 1845.600 MB/sec
[ 0.200040] 8regs : 1373.600 MB/sec
[ 0.300078] 32regs : 1324.000 MB/sec
[ 0.400112] neon : 2098.400 MB/sec
[ 0.400114] xor: using function: neon (2098.400 MB/sec)
[ 0.400121] pinctrl core: initialized pinctrl subsystem
[ 0.400517] NET: Registered protocol family 16
[ 0.401961] DMA: preallocated 1024 KiB pool for atomic coherent allocations
[ 0.404198] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
[ 0.404201] hw-breakpoint: maximum watchpoint size is 8 bytes.
[ 0.404315] Serial: AMBA PL011 UART driver
[ 0.405012] bcm2835-mbox 3f00b880.mailbox: mailbox enabled
[ 0.405203] uart-pl011 3f201000.serial: could not find pctldev for node /soc/gpio@7e200000/uart0_pins, deferring probe
[ 0.580352] raid6: int32x1 gen() 205 MB/s
[ 0.750280] raid6: int32x1 xor() 190 MB/s
[ 0.920462] raid6: int32x2 gen() 329 MB/s
[ 1.090486] raid6: int32x2 xor() 248 MB/s
[ 1.260507] raid6: int32x4 gen() 339 MB/s
[ 1.430532] raid6: int32x4 xor() 268 MB/s
[ 1.600619] raid6: int32x8 gen() 334 MB/s
[ 1.770721] raid6: int32x8 xor() 248 MB/s
[ 1.940753] raid6: neonx1 gen() 703 MB/s
[ 2.110773] raid6: neonx1 xor() 700 MB/s
[ 2.280831] raid6: neonx2 gen() 1048 MB/s
[ 2.450894] raid6: neonx2 xor() 983 MB/s
[ 2.620952] raid6: neonx4 gen() 1501 MB/s
[ 2.791019] raid6: neonx4 xor() 1306 MB/s
[ 2.961078] raid6: neonx8 gen() 1442 MB/s
[ 3.131154] raid6: neonx8 xor() 1164 MB/s
[ 3.131157] raid6: using algorithm neonx4 gen() 1501 MB/s
[ 3.131159] raid6: .... xor() 1306 MB/s, rmw enabled
[ 3.131162] raid6: using neon recovery algorithm
[ 3.131383] bcm2835-dma 3f007000.dma: DMA legacy API manager at bc813000, dmachans=0x1
[ 3.132090] SCSI subsystem initialized
[ 3.132193] usbcore: registered new interface driver usbfs
[ 3.132216] usbcore: registered new interface driver hub
[ 3.132261] usbcore: registered new device driver usb
[ 3.133242] raspberrypi-firmware soc:firmware: Attached to firmware from 2018-05-08 17:30
[ 3.134131] clocksource: Switched to clocksource arch_sys_counter
[ 3.194114] VFS: Disk quotas dquot_6.6.0
[ 3.194190] VFS: Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
[ 3.194314] FS-Cache: Loaded
[ 3.194425] CacheFiles: Loaded
[ 3.198248] NET: Registered protocol family 2
[ 3.198637] TCP established hash table entries: 8192 (order: 3, 32768 bytes)
[ 3.198691] TCP bind hash table entries: 8192 (order: 4, 65536 bytes)
[ 3.198783] TCP: Hash tables configured (established 8192 bind 8192)
[ 3.198856] UDP hash table entries: 512 (order: 2, 16384 bytes)
[ 3.198878] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes)
[ 3.199032] NET: Registered protocol family 1
[ 3.199290] RPC: Registered named UNIX socket transport module.
[ 3.199293] RPC: Registered udp transport module.
[ 3.199294] RPC: Registered tcp transport module.
[ 3.199297] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 3.200252] hw perfevents: enabled with armv7_cortex_a7 PMU driver, 7 counters available
[ 3.201443] workingset: timestamp_bits=14 max_order=18 bucket_order=4
[ 3.205165] FS-Cache: Netfs 'nfs' registered for caching
[ 3.205459] NFS: Registering the id_resolver key type
[ 3.205476] Key type id_resolver registered
[ 3.205478] Key type id_legacy registered
[ 3.205486] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
[ 3.205758] JFS: nTxBlock = 7479, nTxLock = 59835
[ 3.210262] SGI XFS with ACLs, security attributes, realtime, no debug enabled
[ 3.213442] async_tx: api initialized (async)
[ 3.213475] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 250)
[ 3.213535] io scheduler noop registered (default)
[ 3.213538] io scheduler deadline registered
[ 3.213665] io scheduler cfq registered
[ 3.213668] io scheduler mq-deadline registered
[ 3.213671] io scheduler kyber registered
[ 3.213742] io scheduler bfq registered
[ 3.215207] BCM2708FB: allocated DMA memory fb910000
[ 3.215222] BCM2708FB: allocated DMA channel 0 @ bc813000
[ 3.219945] Console: switching to colour frame buffer device 82x26
[ 3.222470] vc-mem: phys_addr:0x00000000 mem_base=0x3ec00000 mem_size:0x40000000(1024 MiB)
[ 3.222664] vc-sm: Videocore shared memory driver
[ 3.222786] gpiomem-bcm2835 3f200000.gpiomem: Initialised: Registers at 0x3f200000
[ 3.227173] loop: module loaded
[ 3.227181] Loading iSCSI transport class v2.0-870.
[ 3.227544] libphy: Fixed MDIO Bus: probed
[ 3.227682] usbcore: registered new interface driver lan78xx
[ 3.227704] usbcore: registered new interface driver ax88179_178a
[ 3.227728] usbcore: registered new interface driver smsc95xx
[ 3.227754] usbcore: registered new interface driver cdc_ncm
[ 3.227757] dwc_otg: version 3.00a 10-AUG-2012 (platform bus)
[ 3.455534] Core Release: 2.80a
[ 3.455540] Setting default values for core params
[ 3.455553] Finished setting default values for core params
[ 3.655668] Using Buffer DMA mode
[ 3.655671] Periodic Transfer Interrupt Enhancement - disabled
[ 3.655673] Multiprocessor Interrupt Enhancement - disabled
[ 3.655677] OTG VER PARAM: 0, OTG VER FLAG: 0
[ 3.655692] Dedicated Tx FIFOs mode
[ 3.655890] WARN::dwc_otg_hcd_init:1046: FIQ DMA bounce buffers: virt = 0xbb904000 dma = 0xfb904000 len=9024
[ 3.655903] FIQ FSM acceleration enabled for :
Non-periodic Split Transactions
Periodic Split Transactions
[ 3.655906] dwc_otg: Microframe scheduler enabled
[ 3.655933] WARN::hcd_init_fiq:459: FIQ on core 1 at 0x8084f9b8
[ 3.655937] WARN::hcd_init_fiq:460: FIQ ASM at 0x8084fd30 length 36
[ 3.655943] WARN::hcd_init_fiq:486: MPHI regs_base at 0xbcc7a000
[ 3.655969] dwc_otg 3f980000.usb: DWC OTG Controller
[ 3.655984] dwc_otg 3f980000.usb: new USB bus registered, assigned bus number 1
[ 3.656001] dwc_otg 3f980000.usb: irq 62, io mem 0x00000000
[ 3.656035] Init: Port Power? op_state=1
[ 3.656037] Init: Power Port (0)
[ 3.656132] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[ 3.656137] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 3.656141] usb usb1: Product: DWC OTG Controller
[ 3.656145] usb usb1: Manufacturer: Linux 4.14.39-1-ARCH dwc_otg_hcd
[ 3.656148] usb usb1: SerialNumber: 3f980000.usb
[ 3.656433] hub 1-0:1.0: USB hub found
[ 3.656455] hub 1-0:1.0: 1 port detected
[ 3.656704] dwc_otg: FIQ enabled
[ 3.656706] dwc_otg: NAK holdoff enabled
[ 3.656708] dwc_otg: FIQ split-transaction FSM enabled
[ 3.656712] Module dwc_common_port init
[ 3.656801] usbcore: registered new interface driver uas
[ 3.656842] usbcore: registered new interface driver usb-storage
[ 3.656858] usbcore: registered new interface driver ums-alauda
[ 3.656875] usbcore: registered new interface driver ums-cypress
[ 3.656894] usbcore: registered new interface driver ums-datafab
[ 3.656910] usbcore: registered new interface driver ums_eneub6250
[ 3.656926] usbcore: registered new interface driver ums-freecom
[ 3.656942] usbcore: registered new interface driver ums-isd200
[ 3.656959] usbcore: registered new interface driver ums-jumpshot
[ 3.656975] usbcore: registered new interface driver ums-karma
[ 3.656993] usbcore: registered new interface driver ums-onetouch
[ 3.657016] usbcore: registered new interface driver ums-realtek
[ 3.657033] usbcore: registered new interface driver ums-sddr09
[ 3.657049] usbcore: registered new interface driver ums-sddr55
[ 3.657066] usbcore: registered new interface driver ums-usbat
[ 3.657234] mousedev: PS/2 mouse device common for all mice
[ 3.657582] bcm2835-wdt 3f100000.watchdog: Broadcom BCM2835 watchdog timer
[ 3.657814] device-mapper: uevent: version 1.0.3
[ 3.657954] device-mapper: ioctl: 4.37.0-ioctl (2017-09-20) initialised: dm-devel@redhat.com
[ 3.658169] device-mapper: multipath round-robin: version 1.2.0 loaded
[ 3.658172] device-mapper: multipath queue-length: version 0.2.0 loaded
[ 3.658174] device-mapper: multipath service-time: version 0.3.0 loaded
[ 3.658180] device-mapper: raid: Loading target version 1.13.0
[ 3.658280] bcm2835-cpufreq: min=1200000 max=1200000
[ 3.658473] sdhci: Secure Digital Host Controller Interface driver
[ 3.658475] sdhci: Copyright(c) Pierre Ossman
[ 3.658651] mmc-bcm2835 3f300000.mmc: could not get clk, deferring probe
[ 3.658797] sdhost-bcm2835 3f202000.mmc: could not get clk, deferring probe
[ 3.658840] Error: Driver 'sdhost-bcm2835' is already registered, aborting...
[ 3.658935] sdhci-pltfm: SDHCI platform and OF driver helper
[ 3.659984] ledtrig-cpu: registered to indicate activity on CPUs
[ 3.660075] hidraw: raw HID events driver (C) Jiri Kosina
[ 3.660204] usbcore: registered new interface driver usbhid
[ 3.660206] usbhid: USB HID core driver
[ 3.660587] vchiq: vchiq_init_state: slot_zero = bb980000, is_master = 0
[ 3.661479] [vc_sm_connected_init]: start
[ 3.668305] [vc_sm_connected_init]: end - returning 0
[ 3.668628] Initializing XFRM netlink socket
[ 3.668639] NET: Registered protocol family 17
[ 3.668734] Key type dns_resolver registered
[ 3.669075] Registering SWP/SWPB emulation handler
[ 3.669742] registered taskstats version 1
[ 3.670248] Btrfs loaded, crc32c=crc32c-generic
[ 3.670583] Key type encrypted registered
[ 3.673385] uart-pl011 3f201000.serial: cts_event_workaround enabled
[ 3.673429] 3f201000.serial: ttyAMA0 at MMIO 0x3f201000 (irq = 87, base_baud = 0) is a PL011 rev2
[ 3.674330] mmc-bcm2835 3f300000.mmc: mmc_debug:0 mmc_debug2:0
[ 3.674334] mmc-bcm2835 3f300000.mmc: DMA channel allocated
[ 3.734456] sdhost: log_buf @ bb907000 (fb907000)
[ 3.772346] mmc1: queuing unknown CIS tuple 0x80 (2 bytes)
[ 3.773837] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
[ 3.775324] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
[ 3.777983] mmc1: queuing unknown CIS tuple 0x80 (7 bytes)
[ 3.814136] mmc0: sdhost-bcm2835 loaded - DMA enabled (>1)
[ 3.814608] of_cfs_init
[ 3.814656] of_cfs_init: OK
[ 3.814873] md: Waiting for all devices to be available before autodetect
[ 3.814875] md: If you don't use raid, use raid=noautodetect
[ 3.815236] md: Autodetecting RAID arrays.
[ 3.815238] md: autorun ...
[ 3.815240] md: ... autorun DONE.
[ 3.815274] Waiting for root device /dev/mmcblk0p2...
[ 3.851429] random: fast init done
[ 3.874189] Indeed it is in host mode hprt0 = 00021501
[ 3.888001] mmc1: new high speed SDIO card at address 0001
[ 3.945056] mmc0: host does not support reading read-only switch, assuming write-enable
[ 3.948497] mmc0: new high speed SDHC card at address aaaa
[ 3.948720] mmcblk0: mmc0:aaaa SL16G 14.8 GiB
[ 3.950701] mmcblk0: p1 p2
[ 3.981754] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
[ 3.981785] VFS: Mounted root (ext4 filesystem) on device 179:2.
[ 3.989132] devtmpfs: mounted
[ 3.990056] Freeing unused kernel memory: 1024K
[ 4.084158] usb 1-1: new high-speed USB device number 2 using dwc_otg
[ 4.084238] Indeed it is in host mode hprt0 = 00001101
[ 4.271456] systemd[1]: System time before build time, advancing clock.
[ 4.334294] usb 1-1: New USB device found, idVendor=0424, idProduct=9514
[ 4.334302] usb 1-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 4.334634] hub 1-1:1.0: USB hub found
[ 4.334682] hub 1-1:1.0: 5 ports detected
[ 4.355922] IPv6: Loaded, but administratively disabled, reboot required to enable
[ 4.365784] ip_tables: (C) 2000-2006 Netfilter Core Team
[ 4.369452] random: systemd: uninitialized urandom read (16 bytes read)
[ 4.376845] random: systemd: uninitialized urandom read (16 bytes read)
[ 4.378534] systemd[1]: systemd 229 running in system mode. (+PAM -AUDIT -SELINUX -IMA -APPARMOR +SMACK -SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD +IDN)
[ 4.378858] systemd[1]: Detected architecture arm.
[ 4.379650] systemd[1]: Set hostname to .
[ 4.422410] random: systemd-gpt-aut: uninitialized urandom read (16 bytes read)
[ 4.674157] usb 1-1.1: new high-speed USB device number 3 using dwc_otg
[ 4.809387] systemd[1]: Created slice System Slice.
[ 4.809622] systemd[1]: Listening on udev Control Socket.
[ 4.810042] systemd[1]: Created slice system-getty.slice.
[ 4.812802] systemd[1]: Listening on Process Core Dump Socket.
[ 4.813298] systemd[1]: Created slice system-netctl\x2dauto.slice.
[ 4.813364] systemd[1]: Reached target System Time Synchronized.
[ 4.813770] systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point.
[ 4.824379] usb 1-1.1: New USB device found, idVendor=0424, idProduct=ec00
[ 4.824386] usb 1-1.1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 4.826845] smsc95xx v1.0.6
[ 4.915998] smsc95xx 1-1.1:1.0 eth0: register 'smsc95xx' at usb-3f980000.usb-1.1, smsc95xx USB 2.0 Ethernet, b8:27:eb:d4:7e:41
[ 5.059841] snd_bcm2835: module is from the staging directory, the quality is unknown, you have been warned.
[ 5.437184] bcm2835-rng 3f104000.rng: hwrng registered
[ 5.454712] snd-hifiberry-digi soc:sound: ASoC: CPU DAI (null) not registered - will retry
[ 5.455189] snd-hifiberry-digi soc:sound: ASoC: CODEC DAI wm8804-spdif not registered - will retry
[ 5.510787] wm8804 1-003b: Failed to read device ID: -121
[ 5.511226] wm8804: probe of 1-003b failed with error -121
[ 5.641240] snd-hifiberry-digi soc:sound: ASoC: CODEC DAI wm8804-spdif not registered - will retry
[ 5.644943] brcmfmac: brcmf_fw_map_chip_to_name: using brcm/brcmfmac43430-sdio.bin for chip 0x00a9a6(43430) rev 0x000001
[ 5.645085] usbcore: registered new interface driver brcmfmac
[ 5.645398] snd-hifiberry-digi soc:sound: ASoC: CODEC DAI wm8804-spdif not registered - will retry
[ 5.723294] FAT-fs (mmcblk0p1): Volume was not properly unmounted. Some data may be corrupt. Please run fsck.
[ 5.819862] brcmfmac: brcmf_c_preinit_dcmds: Firmware version = wl0: Oct 23 2017 03:55:53 version 7.45.98.38 (r674442 CY) FWID 01-e58d219f
[ 5.821000] brcmfmac: brcmf_c_preinit_dcmds: CLM version = API: 12.2 Data: 7.11.15 Compiler: 1.24.2 ClmImport: 1.24.1 Creation: 2014-05-26 10:53:55 Inc Data: 9.10.39 Inc Compiler: 1.29.4 Inc ClmImport: 1.36.3 Creation: 2017-10-23 03:47:14
[ 5.894194] usb 1-1.2: new high-speed USB device number 4 using dwc_otg
[ 5.975316] smsc95xx 1-1.1:1.0 eth0: hardware isn't capable of remote wakeup
[ 6.104934] usb 1-1.2: New USB device found, idVendor=0bc2, idProduct=231a
[ 6.104944] usb 1-1.2: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 6.104948] usb 1-1.2: Product: Expansion
[ 6.104952] usb 1-1.2: Manufacturer: Seagate
[ 6.104956] usb 1-1.2: SerialNumber: NA865PBB
[ 6.106294] usb 1-1.2: The driver for the USB controller dwc_otg_hcd does not support scatter-gather which is
[ 6.106302] usb 1-1.2: required by the UAS driver. Please try an other USB controller if you wish to use UAS.
[ 6.106355] usb 1-1.2: The driver for the USB controller dwc_otg_hcd does not support scatter-gather which is
[ 6.106359] usb 1-1.2: required by the UAS driver. Please try an other USB controller if you wish to use UAS.
[ 6.106365] usb-storage 1-1.2:1.0: USB Mass Storage device detected
[ 6.111314] scsi host0: usb-storage 1-1.2:1.0
[ 6.112103] snd-hifiberry-digi soc:sound: ASoC: CODEC DAI wm8804-spdif not registered - will retry
[ 6.300077] brcmfmac: power management disabled
[ 6.302636] random: crng init done
[ 6.302643] random: 7 urandom warning(s) missed due to ratelimiting
[ 6.404150] usb 1-1.4: new full-speed USB device number 5 using dwc_otg
[ 6.537997] usb 1-1.4: New USB device found, idVendor=21b4, idProduct=0083
[ 6.538006] usb 1-1.4: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 6.538010] usb 1-1.4: Product: AudioQuest DragonFly Black v1.5
[ 6.538014] usb 1-1.4: Manufacturer: AudioQuest
[ 6.538018] usb 1-1.4: SerialNumber: AQDFBL0100102319
[ 7.124614] scsi 0:0:0:0: Direct-Access Seagate Expansion 0707 PQ: 0 ANSI: 6
[ 7.125720] snd-hifiberry-digi soc:sound: ASoC: CODEC DAI wm8804-spdif not registered - will retry
[ 7.506317] smsc95xx 1-1.1:1.0 eth0: link up, 100Mbps, full-duplex, lpa 0xC3E1
[ 11.605191] hid-generic 0003:21B4:0083.0001: hiddev96,hidraw0: USB HID v1.11 Device [AudioQuest AudioQuest DragonFly Black v1.5] on usb-3f980000.usb-1.4/input2
[ 11.605563] snd-hifiberry-digi soc:sound: ASoC: CODEC DAI wm8804-spdif not registered - will retry
[ 11.631080] snd_usb_audio: unknown parameter 'nrpacks' ignored
[ 11.635240] snd-hifiberry-digi soc:sound: ASoC: CODEC DAI wm8804-spdif not registered - will retry
[ 11.641207] snd-hifiberry-digi soc:sound: ASoC: CODEC DAI wm8804-spdif not registered - will retry
[ 11.641294] usbcore: registered new interface driver snd-usb-audio
[ 12.270133] brcmfmac: power management disabled
[ 12.374508] sd 0:0:0:0: [sda] 3907029167 512-byte logical blocks: (2.00 TB/1.82 TiB)
[ 12.374796] sd 0:0:0:0: [sda] Write Protect is off
[ 12.374803] sd 0:0:0:0: [sda] Mode Sense: 47 00 00 08
[ 12.375104] sd 0:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[ 12.403099] sda: sda1
[ 12.405094] sd 0:0:0:0: [sda] Attached SCSI disk
[ 14.261001] fuse init (API version 7.26)
###### PHP backend ######
php version: 5.5.19
debug level: 0
Music!
arnaldo
Postby Kilgore » 11 Oct 2023, 10:17
FYI - I saw this post on DIYaudio site that states that.....
rAudio-1 is an Arch Linux-based, active and constantly improved fork of the abandoned audio player project called Runeaudio.
rAudio-1 is available for all Raspberry Pi's:
https://www.diyaudio.com/community/thre ... is.381003/
I haven't tried rAudio-1 myself yet...I am currently running rune 0.4 and have been for many years but I plan to give it a go as it appears to be more acitve than this site. It also supports multiroom playback which would be handy for me.
Cheers and good luck!
Kilgore
