Postby hondagx35 » 11 Mar 2017, 21:32
Postby hondagx35 » 11 Mar 2017, 21:34
Hi thedman!
sorry I have only the ALLO Boss and ALLO Piano 2.1 available so no possibility to test this.
Postby Multi » 12 Mar 2017, 09:50
Frank,
Thank you for the good work.
I have a question about storage webradio.
In 0.3 Samba was on by default, in 0.4 you need to enable and start Samba (once with systemctl)
In 0.3 in Windows Explorer you see Musicstore with the following sub directories: LocalStorage, NAS, Podcast, USB and Webradio
In 0.4 you see MusicLocalStorage, MusicStoreNAS and MusicStoreUSB
The thing is when you copied a list of pls and m3u files in the directory Webradio of 0.3 version and than add one webstation in the GUI all webstations in the directory will be added.
How to make the webradio directory visible again in Windows Explorer with 0.4 version?
Multi
Multi
Postby Multi » 12 Mar 2017, 10:33
Frank,
Question about Webradio is solved.
I modified the Samba configuration.
Multi
Multi
Postby hondagx35 » 12 Mar 2017, 12:20
Postby Multi » 12 Mar 2017, 14:15
Frank,
Thank you, that was indeed what i did.
I have another question about something i noticed in daily use.
When selecting a stream or track in the queue, Runeaudio locate that track in the middle of the queue list.
That movement is often not straight in one movement and more nervous than i was used to in former versions.
You can test it best to add 40 tracks to the queue. Especially the 9th track from the top is behaving strange.
Multi
Multi
Postby Stymieddd » 12 Mar 2017, 17:20
Frank,
Thank you for sharing your 0.4 beta with us!
Stymieddd
Postby mrcrowley » 12 Mar 2017, 19:57
mrcrowley
Postby hondagx35 » 12 Mar 2017, 23:09
Hi mrcrowley,
you have to use the new image (no update possible) and it only works for RP2/3.
Postby mrcrowley » 13 Mar 2017, 12:59
Ok. Thank you for information.
I misunderstanded it because of the same number (0.4) that i found on my RuneAudioRemote.
Thks
mrcrowley
