Postby s.k. » 16 Sep 2018, 10:07
Hi guys,
More or less for the same reasons I am stick with Rune.
Thanks a lot for your contribution.
I really appreciated.
How about Rern’s add-ons?
I believe that they adding a great value.
I tried to install them over your build, but with no success.
Stavros
s.k.
Postby nic » 16 Sep 2018, 10:13
I've been a happy user of 0.5b for the past few weeks and really appreciate Janui's help getting my DAC working with the new image . I've run into a slight issue when casting , I get 'twiitering noises' type static . I have rebooted the PC used for casting , rebooted the PI and also done a gitpull . This issue happens with MP3 cast from my PC , WAVs now seen fine . Any ideas ?
cheers
Nic
nic
Postby rastus » 16 Sep 2018, 10:44
rastus
Postby rastus » 16 Sep 2018, 10:46
rastus
Postby rastus » 16 Sep 2018, 10:48
rastus
Postby rastus » 16 Sep 2018, 10:53
rastus
Postby Stephane » 16 Sep 2018, 11:00
Maybe because I have been using this version for a while and saw the same screen on my touchscreen ?
Using a Bonjour browser will show you if the player is connected.
Stéphane Acounis
Stephane
Postby s.k. » 16 Sep 2018, 11:51
s.k.
Postby janui » 16 Sep 2018, 14:44
Postby rainy » 16 Sep 2018, 14:47
Hi All,
Just like the previous version (0.3 beta) on the Raspberry Pi1, a USB stick or external USB drive formatted with the ext4 format does not seem to work with Rune Audio 0.5 beta.
Since Rune is based on Arch Linux, I would have expected this to work out of the box. Has anyone else had success with ext4?
Rune can see my USB drive and folders but all folders appear empty (I can see all the audio files when I SSH into Rune). The files on my USB drive are FLAC and Vorbis.
Can the devs please confirm if ext4 is supported on the Rpi images? If not is there a reason or plans to fix? I can only play my audio files with Rune if they are on a USB drive formatted as NTFS.
Many thanks.
rainy
