Postby nkwhahaha » 10 Oct 2018, 14:14
nkwhahaha
Postby popov » 10 Oct 2018, 19:30
popov
Postby Sn4kY » 11 Oct 2018, 08:09
Sn4kY
Postby Sn4kY » 11 Oct 2018, 08:33
Hi everybody.
Yesterday I was installing for the first time RuneAudio, for testing purpose.
This is very nice ! but...
- I've noticed one bug, on the wifi management process :
My wifi has a "+" character in the SSID : "P+M_5GHZ". It's valid for all platforms but RuneAudio can't connect to It.
After dumping the configuration, I've understood why... The wifi configuration file stored in the "/etc/[can't remember the name]/" Directory was named by RuneAudio "P M_5GHZ", and the config inside contains too this bad SSID name.
To solve this issue, I've just unpacked the tarball backup config file, renamed correctly the file (with the "+" character), changed the SSID inside the config file, tar gz the whole directory and restore the backup tarball by normal process.
It's now working like a charm, but it's a little bit confusing... where Volumio (that i've tested just before) works perfectly.
- Other thing, to "burn" the runeaudio image to a SD file, Windows users must uncompress the .img.gz first, so with the popular img burner Win32DiskImager, we are NOT able to sha256sum the GZ file (this app embeed checksum tester, but only with .img files)...
I think it's better to provide the SHA256 of the .img directly (or maybe both), so even if the zipping/unzipping process failed for some reason, we could known that the image we get was corrupted.
For Windows users there is one good option to verify the checksum of any kind of file with Windows powershell (right click with SHIFT key, and select "Open Poweshell window here" (or something like that, my windows is in French), and type :
Get-FileHash .\20180903_runeaudio_rpiB2.img -Algorithm SHA256 | Format-List
The cksum of gunzipped file is
Hash : B27CB298536EB163C20B50FBEED033263D4BCD4D5226F6A239BECE26BFD414A7
- Third thing (only cosmetic I think), I've used a HIFIBERRY DIGI+ PRO, but there is any in the configuration I²C list. Only Digi Plus, Digi Pro, etc. "Digi Pro" doesn't exists at , so I setup with DIgi Pro, and it's working.
Again, thanks for your good work !!
Sn4kY
Postby janui » 11 Oct 2018, 08:58
HI Sn4kY,
Thanks for your feedback, I will look in detail at the problems and suggestions. When I fix these, patches will be available using git pull. See the first post in this thread for update instructions.
Postby janui » 11 Oct 2018, 09:27
Postby nkwhahaha » 11 Oct 2018, 12:46
nkwhahaha
Postby jlynton » 11 Oct 2018, 16:24
jlynton
Postby janui » 11 Oct 2018, 19:53
Postby jlynton » 11 Oct 2018, 19:56
Thanks Janui, I will do so as soon as it stops again, and post the result. I do not need to run the commands as su, right?
jlynton
