Postby s.k. » 01 Nov 2018, 09:02
OK, thanks Janui, it's the Pi2 image that interest me.
Did you upgrade Frank's lirc installation?
If yes, is it possible to roll back.
I'm intent to give a try and keep you informed.
Sent from my ONEPLUS A5000 using Tapatalk
s.k.
Postby janui » 01 Nov 2018, 09:35
Postby s.k. » 01 Nov 2018, 11:06
Me also I prefer having the current version working.
But I'm quite unfamiliar with coding in general - linux in particular.
So, I shall give a try and I'llpost my findings here.
If something doesn't works, I will ask for your help.
s.k.
Postby s.k. » 01 Nov 2018, 18:36
s.k.
Postby humschti » 02 Nov 2018, 13:14
I've setup a new Installation - almost everthing works well. Thanks for your work!
However, I connect my Amp by using the 3.5mm jack - unfortunaletly the Output is very low, even on 100%. Anything I can do to troubleshoot this issue?
humschti
Postby hondagx35 » 02 Nov 2018, 13:48
Postby cmh714 » 02 Nov 2018, 15:40
@humschti, you can also get there via the UI..... use IP:8080 and that should bring up the alsamixer UI in the browser.
Postby hondagx35 » 02 Nov 2018, 16:45
Postby janui » 02 Nov 2018, 16:49
Postby Toube » 03 Nov 2018, 19:32
Hi Guys,
how can I enable WOL on the 0.5 version Arch Linux eth0 adapter or has anyone ever tried it?
Not that a Raspberrypi needs to be shut down. Just curious.
-Toube
Toube
