Postby hondagx35 » 03 Nov 2018, 23:47
Hi Toube,
there is no WOL support on our loved Raspberry Pis.
Postby Toube » 04 Nov 2018, 08:07
Toube
Postby s.k. » 04 Nov 2018, 21:40
Hi ,
Who is the proper way to deactivate the Bluetooth and the Wi-Fi in the Pi2 image ?
By modification of /boot/config.txt, of the /etc/modprobe.d/disable_rpi3_wifi_bt.conf file, of both files , or something else ?
Thanks in advance
Stavros
s.k.
Postby janui » 04 Nov 2018, 23:18
Postby hondagx35 » 04 Nov 2018, 23:23
Postby s.k. » 04 Nov 2018, 23:26
Thanks allot both of you.
I really appreciate your instand support.
Stavros
Sent from my ONEPLUS A5000 using Tapatalk
s.k.
For who may concern to setup an IR remote on v0.5b
Postby s.k. » 05 Nov 2018, 00:10
s.k.
Postby MikeC » 05 Nov 2018, 16:49
Re update: Build version: janui-20180903-5
The latest version of the update seems to have broken my ability to mount network sources. I've rebuilt the OS and it is still an issue only after a gitpull. I tried the sd chip in other Pi's no luck (Pi2B and Pi3B+). I had to used a restore from another Rune with Build version: janui-20180903-4 to get this working again.
Also while on subject of updates:
With Build version: janui-20180903-4 I had to remove my network source when using my mobile unit in AP mode. It kept trying the round robin source mount continuously. Not a big deal since I prefer to keep an SD aside just for AP mode, just letting you know.
MikeC
MikeC
Postby Toube » 05 Nov 2018, 17:52
I'm still using the first version 20180903.. since I tried the gitpull from the dev a week ago and after I tried to reboot it wouldn't start so I flashed it back to the first version.
Should the gitpull from dev work or do one need to use the command interpreter for this?
-Toube
Toube
Postby cmh714 » 05 Nov 2018, 18:01
