Postby Gabriel Syme » 08 Nov 2018, 16:42
installed 0.5 last night. Music sounds great and server is working very well, except for one minor problem. On the monitor connected to HDMI out, the playing time does not increment consistently, or at times, not at all.
Just to be clear, the play time works fine on the main screen. It is on the info screen that time does not work.
https://pastebin.com/embed_js/GubWxf1Y
Thanks for the great product and the hard work needed to make it happen!
Gabriel
Gabriel Syme
Postby RoyB » 08 Nov 2018, 16:56
I'm new here on this forum, and an enthusiastic user of RuneAudio for several years. Much appreciated all the effort done by Frank, janui, Gearhead and others. Hats off for their skills!
For about half a year I use a Pi 3B combined with DigiOne and RuneAudio version janui-20171120. This combination works very nice.
Recently I tried to upgrade to 0.5-Beta janui-20180913. With this I experience an unstable mounting of a USB-Hard Disk.
At startup the HD is most of the times recognized as an USB mount, but the content is not visible via the Library. I have to initiate a full rebuild of MPD, to get the contents available. Sometimes even the HD is not recognized as a mount or disappears.
Auto mount is selected. I checked the health of the external HD and tried also another one. As far as I figured out there is no power supply issue.
Another related problem is that every time the queue-list gets lost after shutdown and next startup.
What could be the problem?
RoyB
RoyB
Postby janui » 08 Nov 2018, 21:42
Postby janui » 08 Nov 2018, 22:00
Postby jlynton » 09 Nov 2018, 11:00
jlynton
Postby Galder » 09 Nov 2018, 15:21
Hi!
I managed to get it work on my Raspberrypi/Hifiberry Digi + combo
Before I have used version 0.4 a couple of years.
I only use Runeaudio to stream Tidal (Hi-Fi quality) and use a android app BubbleUpnp as user interface.
It took me a while to figure out that I had to manually choose upnp option, which was automatic in version 0.4
That I also had to choose I2s for the Digi + did I remembered as it was so even in version 0.4
But if you are not familiar with this I can think that a lot of people don’t understand how this work. I think you should describe this in a tutorial because not all is an advanced technician.
One question, is something done sound-wise to achieve improvements in that area?
And thank you for your hard work.
I’m pushing people to use your software in an audio forum, -spreading the message. ;)
Galder
Postby Toube » 09 Nov 2018, 23:12
Great work @janui 8-)
Any news on the YouTube plugin?
Toube
Postby RoyB » 10 Nov 2018, 15:57
RoyB
Postby Beelzebassie » 10 Nov 2018, 17:57
Something I noticed the other day was that 0.5b does not correctly implement "INDEX 00" attributes in CUE-sheets (intended to define pauses); 0.4b nicely skipped them, while 0.5b ignores them and plays them.
Beelzebassie
Postby Gabriel Syme » 12 Nov 2018, 12:47
What is the easiest way to remove the volume control from the UI in 0.5. I am not having any luck doing searches for this topic.
Thank you.
Gabriel
Gabriel Syme
Users browsing this forum: No registered users and 32 guests
