Postby ayase1121 » 24 Nov 2018, 05:36
Hello, everyone! First, I congratulate the new version of runeaudio! And thank you very much!
The construction of the file is just different from the version until the before by this new version, isn't it? Therefore I have trouble with tuning up.
This my question is a way of indication of a mouse cursor. It was possible to take out a cursor by rewriting of '/root/.xinitrc' by the old version, but '/root/.xinitrc' isn't found by the new version.
Please give counsel.
ayase1121
Postby hondagx35 » 24 Nov 2018, 13:15
Postby janui » 24 Nov 2018, 17:45
Postby thanhvo31 » 25 Nov 2018, 02:01
thanhvo31
Postby ayase1121 » 25 Nov 2018, 04:43
Hello!
I use raspberry pie 3B. And a liquid crystal display of external is being linked. The resolution of the display is 1920 x 1080, but even if it's set as its resolution, a right screen doesn't go out.
The screen won't be the full screen, and a gap is uncrowded in left, right, up or down. It develops in the side. The indicated character is also difficult to spread and see.
Where should I set?
It took one night yesterday, and I tried arrangement, but it was the result satisfied neither.
Is there a good plan?
ayase1121
Postby janui » 25 Nov 2018, 11:20
Postby janui » 25 Nov 2018, 11:40
Postby Velociraptor » 25 Nov 2018, 16:28
Hej,
so thanks for the effort and also for porting it to my old RPI-1 which I tested and can give an ACK as in acknowledged working :)
Of course its slow but that's not the point =) also I wanted to know if the multi-room feature which was somewhere in the forum will come to this release?
Because, this way I might be able to offload the heavy duty HDD indexing to another more potent device and still use the Hifiberry DAC on the RPI1.
Velociraptor
Postby IgroupyJiast » 27 Nov 2018, 11:57
IgroupyJiast
Postby tml3nr » 27 Nov 2018, 14:07
tml3nr
