Postby vennesch » 05 Dec 2018, 10:50
Remove
vennesch
Postby vennesch » 07 Dec 2018, 12:56
Thanks for answering my questions Janui. One more thing. I get: cannot connect to Add Ons server. Anyone else with this problem? My internet connections are good.
Fixed, By uninstalling and installing again.
vennesch
Postby thedman! » 07 Dec 2018, 14:57
thedman!
Postby thedman! » 07 Dec 2018, 15:00
Any progress on .m3u8 streams?
thedman!
Postby janui » 08 Dec 2018, 13:47
Postby R101 » 08 Dec 2018, 14:16
Hi Janui,
Rune v0.4b has been able to play the BBC m3u8 feeds since the MPD upgrade addon became available. Rune v0.5 does not play them, so this does appear to be a regression.
Postby janui » 09 Dec 2018, 10:37
Postby R101 » 09 Dec 2018, 11:02
Hi janui,
Music Player Daemon 0.20.11
Postby Colin » 14 Dec 2018, 12:00
Hi everyone,
And first of all, thank you for your great work on RuneAudio. I have installed that beta version on a Pi 3B+ and almost everything works great out of the box.
I think I will probably fix some little things locally (for example, I'd love to add a "Rotation" setting for the local touchscreen in the UI).
To do this and be able to contribute back, I think I'll have to be able to locally build Runeaudio images in a clean way, starting from git clones of your upstream code.
If I understand correctly, the official repos lag behind and this beta image has been generated from gearhead's forks:
https://github.com/gearhead/RuneUI
https://github.com/gearhead/RuneOS
and these are the repositories I should fork to be able to send merge requests. Can you confirm that ?
Also, I didn't manage to find documentation on how to generate a complete .img from sources. Is there such a documentation somewhere ?
Thanks in advance,
Colin
Colin
Postby janui » 15 Dec 2018, 09:38
