Hey all,
0.5-beta currently rocking out on a Pi 3 b+ (2017) with a HiFiBerry DAC+ Pro. (Volume output seems lower than previous versions)
***EDIT - Seems I hadn’t set the volume control to Hardware on the MPD tab - nearly took my ears and speakers out***
I did notice that the I2S kernel module is showing RaspyPlay4 - even though I selected HiFiBerry DAC Plus Pro.
- Would I be as well hardsetting the HiFiBerry in the overlays section?
Few tiny tweaks like disabling the WiFi and BT all done as I run browsers over my LAN to use Rune.
QNAP iTunes (FireFly server) took a bit of figuring out, I ended up having to create a NAS user account with RO provilleges to the Multtimedia folder. CIFS auto discovered when I setup the Share in Rune and now it seems to work like a charm.
Just one question though:
From default install, is this beta set for true headless or does it load in display (7’ pane; drivers etc..) - I’m powering the Pi from a Netgear Clicksmart USB charger port at the moment so would like to trim out as much as possible.
Top job to the 0.5 beta-devs and happy holidays.
