Postby rlsten » 18 Sep 2018, 00:10
Thanks very much for your new image--I also have tried the others and always return to Rune--it simply sounds best.
I use rune with an Adafruit 2.8" touch screen, and it works with the new image. However, because of the switch to Chromium from Midori, and I can't access the Addons menu, and specifically, the UI enhancements, I don't know how to change the zoom level on the new image to fit on my tiny screen. With midori I could edit /root/.config/midori/config to change the zoom level. Is there a similar file for Chromium that I can access, or is there some other way to change the zoom level?
Thanks very much,
Rod
rlsten
Postby MidnightExpress » 18 Sep 2018, 10:51
Pi3b+, Ver. Experimental Beta 0.5 20180903, ES9018K2M Dac
MidnightExpress
Postby janui » 18 Sep 2018, 10:56
Postby Stephane » 18 Sep 2018, 11:53
I also tested some scale factors to use Rune 0.5b on a 7" touchscreen. I found that the switch "--force-device-scale-factor=0.8" does the job ... more or less.
The round circle of the volume knob is clipped and thus not make a circle anymore. I found also that the fonts are too small but what make Chromium more annoying to use is the way it handles long finger press as it brings a popup menu.
One way to have a nice display on small screens would be to use a custom CSS file but it is disabled in Chromium.
So I switched back to 0.4B as I fond the way Midori works more suited to my needs.
Stephane
Postby jlynton » 18 Sep 2018, 12:37
I have just set up 0.5-beta on my pi3b, and have no problems except that I cannot access the web interface with runeaudio.local - I can access it using the pi's IP. Is this normal? I can access it using the android app.
jlynton
Postby janui » 18 Sep 2018, 13:20
Postby janui » 18 Sep 2018, 13:48
Postby rlsten » 18 Sep 2018, 13:59
rlsten
Postby jlynton » 18 Sep 2018, 14:38
jlynton
Postby janui » 18 Sep 2018, 14:44
