Postby s.k. » 03 Jan 2019, 16:27
Digione gives spdif output and if you seek "bit perfect" playback, don't use the volume control.
Otherwise works OK.
Regarding the setup, digione is one of the supported devices.
You have only to select it, after enabling the I2S output.
Sent from my ONEPLUS A5000 using Tapatalk
s.k.
Postby Toube » 03 Jan 2019, 17:17
Toube
Postby cmh714 » 03 Jan 2019, 17:54
Postby Vhond » 05 Jan 2019, 14:11
Found another bug (couldn't find this as already posted):
When I add a mount share (Sources) and I select NFS, I couldn't switch off the guest user. Therefore I couldn't fill in user credentials (user password information). I had first to switch to SMB/CIFS before I could switch off guest user and another time to fill in the user and password info).
Finally my library started updating
Vhond
Postby Vhond » 05 Jan 2019, 14:17
Another question: as I use an app on my smart phone I now can see Runeaudio as a SMB device?? I am connected via NFS to my NAS but what is Runeaudio sharing using SMB??
Vhond
Postby janui » 06 Jan 2019, 15:44
Postby janui » 06 Jan 2019, 16:48
Postby Vhond » 07 Jan 2019, 12:03
Vhond
Postby humschti » 07 Jan 2019, 14:36
Hi!
I have a strage issue: Alsamixer is loosing its settings on reboot (well, not on all reboots but on most of them). Sound is very weak when the config is reseted.
sudo alsamixer doesn't resolve the issue.
Any idea?
cheers,
martin
humschti
Postby janui » 07 Jan 2019, 14:59
