Postby konki » 17 Mar 2019, 13:28
Thanks janui for your quick reply, Rern's addons RuneUI enhancement is compatible with 0.5beta (works fine under Linux and Windows with any browser). This is a strange behavior under Android and ios. I add a post in addon's section.
edit 20190319 all warnings will be fixed in next update of RuneUIe , Thanks rern
konki
konki
Postby nic » 18 Mar 2019, 21:09
I tried the manual gitpull , issue remains the same then tried the reinstall script , the same error still occurs.
It's working so I'll keep using as is for the time being
cheers
Nic
nic
setting of additional "your-extra-mpd.conf" doesn't work
Postby werdandi » 20 Mar 2019, 14:23
hardware: raspberry 3b+ (latest), DAC -> "Project RS USB Audio 2.0"
software: RuneOs: Experimental Beta 0.5 20180903, RuneUI: 0.5b (gearhead), Hw-env: RaspberryPi 2 / 3
due to the mpd.conf on every startup will be overwritten/rebuilt the only possibility to amend options/configurational aspects to the mpd.conf (that are not covered by the available UI) is, to set an additional file in the /home directory, named "your-extra-mpd.conf" containing the desired options.
so i did:
root@runeaudio(rw):/home# ls -alh
total 12K
drwxr-xr-x 2 root root 4.0K Feb 28 18:29 .
drwxr-xr-x 18 root root 4.0K Sep 9 2018 ..
-rw-r--r-- 1 root root 851 Mar 19 17:54 your-extra-mpd.conf
contains:
## your-extra-mpd.conf ##
## Playlist Plugin Example ##
# This is an example for adding a Playlist Plugin to MPD
# You could use this file for setting many other MPD options
# This file needs to be placed in the directory /home to activate it
# Set the correct file protections with the command: chmod 644 /home/your-extra-mpd.conf
audio_output {
name "Project RS USB Audio 2.0"
type "alsa"
device "hw:1,0"
dsd_usb "yes"
format"352800:24:2"
auto_resample "yes"
auto_format "no"
playlist_plugin {
name "m3u"
enabled "true"
playlist_plugin {
name "extm3u"
enabled "true"
## end your-exta-mpd.conf ##
############################D
-> the playlist content (what i'm not primarily interested in) indicates that i copied this sample from an other post in this forum.
my main goal is to get the audio_options working: automatic resample (using soxr, what in principle is already enabled in the existing mpd.conf) of all pcm material to 352khz, 24bit.
the good news is: the system sees no problem with this amended file and the os starts and the player works so far, but ignoring the set options.
can anyone help?
thanks in advance!
werdandi
Postby janui » 20 Mar 2019, 20:44
Postby werdandi » 20 Mar 2019, 21:17
werdandi
Postby hondagx35 » 20 Mar 2019, 23:12
Postby werdandi » 21 Mar 2019, 11:10
hello and thanks again for your help
in principle it worked (interesting: in the play ui the 44.1-16 will be displayed unchanged, but the indicator on the DAC switches to 352 - so far so good. and... yes there is a bit of change in the sound but this impressions and the felt quality (better/worse) is absolutely individual and i really DON'T want to preach any missionary things - at least for me it is a bit of soften the sound and widen of the room ...
anyway BUT: what i told was for pcm material, but my now upcoming problem is: i want to differentiate between pcm and dsd material.
i only want the pcm material treated in that way, but left the dsd material unchanged, due to my dac can handle it directly (or at least over the package format DoP).
is the a way to set this ?
and finally remaining the question of making it stay after a possible reboot
again, thanks in advance
werdandi
Postby janui » 21 Mar 2019, 12:17
Postby werdandi » 21 Mar 2019, 16:26
hello again :-)
at the moment, i can't determine if the set option will be ignored or it simply doesn't work ( i know, it may sound a bit funny, but in case of ignored, i see the chance of correcting a mistake, that i may have done, but in case of not working it's more probable that i cant' do anything against that ...)
the actual behavior after setting this option is: dsd is being played as it is put in, but the pcm material also with its original sample rate properties - so you see, without having any more detailed log output etc. i can't decide if the player plays like initially not using any additional setting, or if in principle the allowed_formats setting partially works, but the implicite upsampling to 352800:24:2 only doesn't work
currently used mpd.conf ->
audio_output {
type "alsa"
device "hw:1,0"
dsd_usb "yes"
dop "yes"
auto_resample "yes"
auto_format "yes"
allowed_formats "352800:24:2 dsd64:=dop dsd128:=dop dsd256:=dop dsd512:=dop"
werdandi
Postby janui » 21 Mar 2019, 17:03
Users browsing this forum: No registered users and 58 guests
