Postby guermantes » 29 Apr 2019, 12:03
Is there any way to "lock" Runeaudio to USB output? Or remove the possibility of MPD selecting the Pi's Analog or HDMI outputs?
I use my Runeaudio quite seldom, but have the problem that every once in a while my external DAC (over USB) disappears from the output interface list. Sometimes I can go into MPD and re-select it, but sometimes it is no longer there and I have to reboot to get it back. I haven't figured out why this is happening.
I have set a cronjob to reboot nightly, and it would be nice to prevent the RPi Analog or HDMI output to be selected during reboot if the DAC is turned off, which it will be during night.
RPi 3B with HiFiBerry Digi+ -> Cambridge DACmagic
guermantes
Postby janui » 29 Apr 2019, 22:32
Postby dynobot » 02 May 2019, 01:52
@janui
Thank you for your hard work on this, you've done a great job!
Concerning Spotify,
I've found a replacement called Spotifyd. I've done a lot of testing and usage over the past month or so, and its very solid, very easy to install and set up and above all actually seems to sound like the native Spotify app.
You can follow and read my testing notes here https://dietpi.com/phpbb/viewtopic.php?f=12&t=2981 under the moniker Edward.
The github repo is here https://github.com/Spotifyd/spotifyd/wi ... spberry-Pi
I've installed it on Rune while testing and using at least 30 times, and have used it with various interfaces like Amanero USB device, XMOS, DigiOne etc.
If you implement it in Rune I would be happy to test and help in any way.
~Ed
dynobot
Postby janui » 02 May 2019, 16:49
Postby guermantes » 04 May 2019, 15:27
guermantes
Postby Paddy_B » 05 May 2019, 09:28
Hello everybody,
I'm new here and wanted to install the rune player to my raspberry 3 b+.
I've downloaded the 0.5 beta and used the win32 disk imager to put it on the sd card. Checksum is okay.
Now when I start the Raspberry, I see the following on my screen:
[3.835267] Error: Driver 'sdhost-bcm2835' is already registered, aborting...
[3.840262] vc-vchi--sm_init: failed to open VCHI service (-1)
[3.840265] [vc_sm_connected_init]: failed to initialize shared memory service
Warning: /lib/modules/4.14.34-1-ARCH/modules.devname not found - ignoring
starting version 238
/dev/mmcblk0p2: clean, 92386/237104 files, 657765/947200 blocks
_
The cursor blinks and nothing more happens.
I hope you can help me.
Best regards Paddy
Paddy_B
Postby janui » 05 May 2019, 15:27
Postby dynobot » 05 May 2019, 15:55
dynobot
Postby Paddy_B » 06 May 2019, 05:56
Paddy_B
Postby Paddy_B » 06 May 2019, 05:59
Paddy_B
