Postby Ripa » 26 May 2019, 11:43
i have bought the Raspdac mini kit,
but it only support volumio and moode.
is there anybody that can help me to work with rune
https://www.audiophonics.fr/en/diy-kits ... 13300.html
http://moodeaudio.org/forum/showthread.php?tid=664
thanks
Ripa
Ripa
Postby janui » 26 May 2019, 12:36
Postby janui » 26 May 2019, 13:08
Postby janui » 26 May 2019, 13:28
Postby Vhond » 26 May 2019, 16:01
Vhond
Postby janui » 26 May 2019, 20:22
Postby Vhond » 27 May 2019, 09:15
Hi Janui,
Thx for your reply. It has a delay for more than a minute in my configuration.
Vhond
Vhond
Postby EZJstef » 03 Jun 2019, 21:28
Hi Janui
so i have just restart a new install on SD card ... i just only configure my DAC, and brower on, i can work MP3 from my PC to my RUNEAUDIO box.... so now i have restart, and after reboot and have several time the picture runeaudio is starting and closing before getting local browser ..... i don't restart again just stay here to have the debug for you
i will try to switch off the wifi access point and conect the RJ45 of internet ..... but it's as this time i get the screen i had sent before and impossible to reconnect via network etc no more possible to sheck somethings , access point disable and no network connect!
sorry for my english i hope you understand what i mean
one problem i have debug but i can post here between the (CODE mode ) how i have to do?
issue "Your message contains 133321 characters. The maximum number of allowed characters is 60000."
thanks a lot, wife getting angry, and it's really boring for me because i am not a real expert !!! so i spend a lot of time to try to understand but no real results !
i just wanted to move to 0.4 to 0.5 ! and i don't keep the 0.4 on sd card at all grrrrr bad idea!!!
many thanks in advance
Stef
EZJstef
Postby janui » 04 Jun 2019, 07:59
Hi EZJstef,
This fix is needed at the moment: rune-ui-is-slow-t6829-10.html#p27995
If you have already done this you can post the first part of your debug (up to and including 'Loaded kernel modules (lsmod)').
Postby mattra » 07 Jun 2019, 10:11
Usb card not showing up in Library.
I have two RaspberryPi3 and use a micro SD card connected via usb to take my music from one device to the other.
Mostly it works perfectly. I switch of the music, then the Raspberry (cut the current), and then take out the usb and put it in the other Rasp. But now the Rasp doesn't recognize the usb Micro SD any more. (Automount is on) I checked the card on my computer, and everything shows up fine.
More info: I wanted to copy something from my computer to the micro sd, but couldn't as all folders were owned by root. So I switched ownership to my user for the card and all folders and files. Could that be a problem? What ownership should the card/folder/files have for Runeaudio to recognise the card?
Or is there another reason why the card is no longer recognised?
Using runeaudio 05b janui-20180903-10
Thanks in advance
mattra
Users browsing this forum: Google [Bot] and 2 guests
