Postby janui » 08 Jul 2019, 06:07
Postby Vhond » 08 Jul 2019, 10:29
Vhond
Postby tixs » 08 Jul 2019, 21:32
(Hopefully) Short question:
I operate two Raspberries with RuneAudio, one on the basis of a Raspberry Pi 2 (together with a HiFiBerry Amp) and one on the basis of a Raspberry Pi 3 B (together with a HiFiBerry DAC+ and with onboard WLAN disabled). Since a new installation takes me up to an hour per player (assuming nothing goes wrong during the setup ...) - would it be possible to install RuneAudio on one player, then clone the SD card and just change player name and HiFiBerry setting (and static IP, if used) for the second player? Or would files and settings need to be adjusted to a larger extent (e.g. because the installation routine implements the software differently during the installation process because of hardware recognition) so that a new installation might still be easier?
tixs
Postby janui » 09 Jul 2019, 15:24
Postby tixs » 09 Jul 2019, 19:01
Great, thanks, janui. That will save me a lot of time.
By the way - did you have a chance to make some progress on the issue I described in an earlier post some time ago?
I'm anxiously waiting for it to be solved so that I can migrate a huge (approx. 1,500) CD collection to RuneAudio - but especially with classical music this didn't make sense so far due to the somewhat improper listing. :cry:
tixs
Postby janui » 10 Jul 2019, 10:29
Postby tixs » 10 Jul 2019, 18:48
Understood. No worries - will continue to wait patiently. (But will probably send a reminder from time to time ... ;) ).
tixs
Postby gerootech » 19 Jul 2019, 04:21
Anyone tried to connect to a Bluetooth speaker using commands ?? i would appreciate any help. I tried commands from BluteTooth commands from Archi Linux but it is not working. I am getting the following error: when i check the status of bluetooth services.
a2dp-sink profile connect failed for xx:xx:xx:xx:xx:xx Protocol not available
gerootech
Postby janui » 19 Jul 2019, 09:11
Postby TFZ02 » 29 Jul 2019, 13:15
already exists a version for the Pi4+?
TFZ02
