Postby DarthG » 28 Sep 2018, 13:39
Thanks janui,
I tried your changes, but it doesn't work.
I think I forgot to remark, that I tried to play directly from an USB-Storage.
The Tracks from the .cue-files are placed in the queue, but they don't start to play.
DarthG
Postby janui » 28 Sep 2018, 14:03
Postby RolandBlaze » 29 Sep 2018, 10:19
Thanks for new build :D appreciated.
RuneAudio+R e6 20201108 
Raspberry Pi 4 Model B Rev 1.
RolandBlaze
Postby thisisjay » 29 Sep 2018, 21:08
So.....I tried Rune .5 beta on another device and this is what happened.
Tried to select my card. I was pretty sure it was an IQ Audio Pi DAC Plus, but when I select "IQ Audio Pi DAC Plus" or "IQ Audio Pi DAC Pro", Rune kept defaulting to "IQ Audio Pi DAC Zero". This could not be right because the only choices I had for output device were HDMI and audio jack. I selected "IQ Audio Pi DAC" and was able to select I2S. I restarted for good measure and could play a file......BUT had no sound.
Reflashed the card with the latest version of Volumio and was greeted by the first run wizard which by default said that I had an I2S device and that it was the IQ Audio Pi DAC Plus....I KNEW IT!! Working! Did all of this on phone using the hotspot. Now listening to music rather than fighting with my PI.
I think Rune does have some advantages over Volumio, but working out of the box is not one of them.
thisisjay
Postby janui » 29 Sep 2018, 22:23
Postby SigMaster » 30 Sep 2018, 12:50
SigMaster
Postby janui » 30 Sep 2018, 13:49
Hi SigMaster,
Thanks for the post, very interesting. The way Rune 0.4 and 0.5 work is the same, but all the packages have been upgraded for 0.5.
If your solution works for nic it is even more interesting, because he uses an I2S DAC (Allo Piano 2.1 & Kali). That would point to a fault in the driver software for the on-board Ethernet adaptor, therefore unrelated to using an USB DAC.
Can anyone else reproduce and/or test this?
Postby R101 » 30 Sep 2018, 15:11
I cannot see how to set the zoom level for the 7" Pi touchscreen. The files used by rern's addon to do this are not in the 0.5b root folder. Should they be?
Postby Stephane » 30 Sep 2018, 16:00
Hi R101,
You'll have to edit this file: /etc/X11/xinit/start_chromium.sh and set the correct level.
Stéphane Acounis
Stephane
Postby R101 » 01 Oct 2018, 12:52
