Postby janui » 15 Sep 2018, 11:14
Current build version: janui-20180903-11
Edit 15-07-2019: This release will not work on the new Raspberry Pi 3A+, Pi 4B or 5B models, but we are working on it.
As you may know, Gearhead and I have been working on updating the rune images. Basically, updating the packages on them as well as fixing bugs in the UI and also adding some functionality. We have created 2 images, for armv6 and v7, which are almost identical. The v6 image for the A/B1/Zero does not have a local browser as it is just too slow. Other than that, they work identically, the UI is the same for both images. We have been running these images for a couple of month now and have been putting them through some serious testing. Recently some other forum members have also contributed to testing and evaluation, many thanks to them for the time and effort. We think the images are now ready for a wider audience and wanted to get them out to you.
We feel that Rune has lagged behind other players a bit as there has not been an update to the B1 image since 2014 and Frank's B2 (v0.4b) image from 2017 was never placed on the download page as an 'official' version for others to find and enjoy. The Pi Zero makes a fine small player and has no current official image. The B3+ is also not supported directly by any of the available official images. These two new images will allow Rune to run on all available and previously available Raspberry Pi devices. We are currently running it on the Pi B+, Zero, Zero W, B2, B3 and a B3+ models. Both Gearhead and I are sold on Rune. We also think it is the best player out there. We have tried the others, did not like them for different reasons and came back to Rune. The UI is quicker and cleaner. It just makes a lot of sense which reflects back to the original group that put it together. We have added functionality but have tried to keep the UI fairly clean. Please let us know how we did.
The OS is running the most current packages (as of April 2018), specifically MPD, upmpdcli and other MPD support programs. All packages have been built for both architectures. We have added Bluetooth support for those devices with BT (only CLI at this time, but it seems to work). The Kernel is patched for 384k support as well as many of the DSD devices. Gearhead has tested 384k/24b support on PCM5122 as well as PCM5102 i2s cards. Another improvement is that we have changed from shairport to shairport-sync. Shairport-sync is fully integrated into the UI. It is much more robust than shairport and is in current development.
We are still making small improvements to the images. After setting up your installation you can use the git pull function in the /dev UI to upgrade to the latest version. For instructions see here: http://www.runeaudio.com/documentation/ ... rd-updates. The current build version is mentioned in the first line of this post. Your current version van be seen in the Debug UI, Build version: janui-20180903-x.
The UI changelog can be found in the repository which we have forked: https://github.com/gearhead/RuneUI/blob ... ngelog.txt
The OS changelog it here: https://github.com/gearhead/RuneOS/blob ... ngelog.txt
Have fun,
Download links:
B1: 20180903_10_runeaudio_rpib1.img.xz for the Pi A, B, B+, Zero and Zero W (5,800+ downloads)
https://www.mediafire.com/file/1kdn6u33 ... mg.xz/file
SHA-256 of the xz: 493890442E634956CBE5C23D5DCD26DD68922C45F764C6C52EA257FF5CF96498
SHA-256 of the img: 82E0BCC40F10546F2F5FCA7441562DAFEE3F94AC0B80C751DBD3D4D6743E54F6
B2: 20180903_10_runeaudio_rpib2.img.xz for the Pi 2B, 3B and 3B+ (15,200+ downloads)
https://www.mediafire.com/file/xzm9fhzu ... mg.xz/file
SHA-256 of the xz: F2F5D34E43D11F42F889E51002E8076DDBAF45647488EBBA31A9C8D612025907
SHA-256 of the img: E7A721C883D637D2F5E5022054EE4CD87D8EAD1DD4E789F4469F9E41900CAD4C
Both images are designed to fit on a 4GB Micro-SD Card.
Note 10-12-2023: Download format changed to xz compression to save space and download time. Contact me via private messages if you miss something.
Postby rastus » 15 Sep 2018, 11:23
Thank you.... 'bout time someone done something. As for feedback, it works.... I like it.
rastus
Postby thedman! » 15 Sep 2018, 16:35
Excellent news!
I've tried all other alternatives but always come back to rune. its the best and simplest, long may it continue. Downloading for a new install now.
Cheers folks!
thedman!
Postby tml3nr » 15 Sep 2018, 16:42
I am very happy to hear RuneAudio continue. Many thanks for your efforts!
tml3nr
Postby J4K » 15 Sep 2018, 18:42
Hi janui,
Rpi3b, RuneAudio 0.5-beta2.
Thank-you for releasing an update, But my fresh install is stuck on the "Starting rune audio" screen with a blinking cursor, and never gets past this.
Cannot collect debug info.
J
J4K
Postby Stephane » 15 Sep 2018, 21:06
You have to connect with a web browser and enable the local browser.
Stéphane Acounis
Stephane
Postby J4K » 15 Sep 2018, 22:34
Hi Stéphane Acounis,
I Cannot connect with a web browser and enable the local browser, as it is stuck at boot up, I get a "Starting RuneAudio image" on my 7" screen, and it goes no further.
I can't even ssh into rune.
Can I enable the local browser in the config file?
J
J4K
Postby thanhvo31 » 16 Sep 2018, 01:35
Nice job, thank you @janui , @Gearhead
I will try ASAP.
thanhvo31
Postby thedman! » 16 Sep 2018, 08:51
Love you can switch samba shares on and off!
thedman!
Postby Stephane » 16 Sep 2018, 09:21
Stephane
Users browsing this forum: Baidu [Spider] and 17 guests
