[SOLVED] Runeaudio 0.5, Pi3b+ touchscreen 5" problem layout
Postby psykoknarf » 31 May 2020, 01:00
Hi all.
I've a problem with my Touchscreen 5" from Waveshare (hdmi lcd G 800x480)
The touchscreen has been recognized on the first config without calibrating or something other stuffs.
My problem:
I can't touch the borders with the stylus. can't use the menu on up-right, can't use the bottom bar.
To try, i've installed TSLIB to calibrate the touch.
The calibration was success, but same problem is on, can't touch the border.
If i touch a corner, the pointer is 5 millimeters out, and if i touch the middle of the screen, it's ok.
If i do a "drag and drop", the pointer still have delay and don't go on the corners, and stay 5 millimeters out.
I've tryed the fonction ts_test and i can go everywhere on the screen, and the pointer go on the corners too.
I don't understand why on test, it works fine, and when i'm on the GUI can't use all the layout.
someone have an idea about that?
thanks a lot
psykoknarf
Re: Runeaudio 0.5, Pi3b+ touchscreen 5" problem layout
Postby psykoknarf » 06 Jun 2020, 14:48
hi again
same problem about the touchscreen from Waveshare 5'' 800x480 HDMI G usbTouch
when calibrating with TS_CALIBRATOR, and TS_TEST all ok.
When i'm on Runeaudio, always a delay with the layout (touch is out 5 milimeters on the edges of the screen)
someone have this problem too, or i?m the only one?
psykoknarf
Postby gearhead » 12 Jun 2020, 15:44
gearhead
Postby psykoknarf » 13 Jun 2020, 14:05
psykoknarf
Postby psykoknarf » 14 Jun 2020, 23:15
LAST NEWS!!!
I've restart an installation with a clear IMG from RUNEAUDIO.
ive tried to install all like you said, and it works great.
Thanks a lot for this help
psykoknarf
