RuneAudio 0.6-beta for most Raspberry Pi models
Re: RuneAudio 0.6-beta for most Raspberry Pi models
Postby janui » 05 Jan 2024, 12:01
Postby RoyB » 08 Jan 2024, 14:59
RoyB
Postby surfninja » 14 Jan 2024, 21:55
I switched to Rern's rAudio a long time ago. However, I just tried 0.6b and it seems to work with my RP2 and Allo HAT.
Mount music nas
rebuild library
added a few web radios
Thanks for the hard work!
rAudio 1, Raspberry Pi 2B
rAudio 1, Raspberry Pi 4B
rAudio 1, Raspberry Pi Zero W
surfninja
Postby phil10503 » 22 Jan 2024, 01:29
THANK YOU, THANK YOU, THANK YOU.
You guys are great. I had been using RuneAudio for several years on an old Pi 3B with v0.3 and really liked it. After a short hiatus, I tried to run it again and couldn't get it to run. Got it all jacked up and resorted to volumio just to get something playing but I really don't like the UI. FINALLY got it all back with this release, and MORE. I love the UI improvements and the ability to setup the wifi during first boot. Everything works perfectly and the UI is wonderful and intuitive. Will be donating shortly.
Thanks again!!!
Phil
Pi 3B with HifiBerry Digi+
Pi 3B+ with HifiBerry Digi+ transformer
Schiit Audio Bifrost MultiBit DAC
Bottlehead Crack Headphone Amp with Speedball
Sennheiser HD 650
phil10503
Postby phil10503 » 23 Jan 2024, 05:07
I'm running the 64bit version on a 3B and Everything works GREAT except for playlists. I made a queue and saved it as a playlist (verified that it is saved in "/var/lib/mpd/playlists") but it won't show up and runeaudio says: "No playlists found, return to queue"
Any help would be greatly appreciated.
Thanks,
Phil
Sennheiser HD 650
phil10503
Postby janui » 26 Jan 2024, 15:25
Postby phil10503 » 26 Jan 2024, 16:55
FANTASTIC !!!
Works perfectly, THANKS,
Phil
Sennheiser HD 650
phil10503
Re: Hick-ups/stutters playing high definition music
Postby janui » 29 Jan 2024, 12:00
Hick-ups playing high definition music files
Postby RoyB » 29 Jan 2024, 13:43
RoyB
Postby Beelzebassie » 30 Jan 2024, 14:07
...testing...
Looking good!
PS. Small cosmetic bug: On the queue tab, the total playtime has a redundant 'h' for a playlist exceeding 1 hour.
Beelzebassie
