Runeaudio built for modern kernel for Pi B+ (armv6)
Postby gearhead » 22 Mar 2017, 01:08
So, I have gone through and have built all the packages in the git repository for an armv6. I posted to the 'issues' for the respostory what I had to change to get it to compile. I have also run through the old 0.3 production cookbook as best I can. Three is a missing package (tcp_wrappers) which I did not install. I had to force install 2 packages (php-rune and samba-rune as pacman complained). I had to copy the /etc/nginx/nginx.conf from a running system. At one point I got is the '404 Not Found' on the web interface. I made a guess and copied the configuration files from RuneOS/config/etc to /etc (this was not in the cookbook) and I still had the 404 and MPD was not running. I finally got MPD running by creating the /var/run/mpd directory and giving mpd ownership. Now it starts and runs and I get the web interface! Should I post this somewhere, Frank?
edit: This was because the sym links were not created or broken - read down further to get this fix: Filesystem upgrade manual intervention
I am playing a net stream right now and it seems to be OK running through my home brew DAC (5122)!
Gearhead
gearhead
Re: Runeaudio built for modern kernel for Pi B+ (armv6)
Postby gearhead » 22 Mar 2017, 01:45
gearhead
Postby hondagx35 » 22 Mar 2017, 11:36
Hi Gearhead,
thank you for your effort to get this working.
I am very busy at the moment, so sorry for not answering your questions on GIT.
I will answer in detail this evening here.
Are you able to upload your image somewhere?
Postby gearhead » 22 Mar 2017, 14:38
gearhead
Postby gearhead » 22 Mar 2017, 17:04
PM sent.
gearhead
Postby surfninja » 22 Mar 2017, 18:43
Gearhead, this might help those x86 users that keep asking about a rune cookbook. Seems like you had to figure out all the steps.
Good job.
rAudio 1, Raspberry Pi 2B
rAudio 1, Raspberry Pi 4B
rAudio 1, Raspberry Pi Zero W
surfninja
Users browsing this forum: No registered users and 55 guests
