RuneAudio doesn't play 44.1khz files
Postby krell » 29 Oct 2017, 13:30
Hi at all,
by some time I have developed a system with RPI3, Hifiberry Dac+ Pro as a reclocker and i2s output to dac (DENAFRIPS Terminator).
It sounds delicious, but I have a problem: files, in any format like flac, wav, etc., at the rate of 44.1 khz are played but are not sounded.
No problem with files at 88.2, 96, 192 and even DSD64.
If I connect Terminator via usb it is recognized correctly (Amanero Combo384) and everything works perfectly.
What can it be?
krell
Re: RuneAudio doesn't play 44.1khz files
Postby janui » 29 Oct 2017, 17:31
Postby krell » 29 Oct 2017, 18:16
Thanks a lot janui,
I followed instructions in the post you linked audiogd-nfb28-es9018-dac-i2s-rpi3-setting-which-works-t4167.html#p18251
and bingo!!!! now all 16 bit files sound :D :D :D
krell
