RuneAudio looses static IP after reboot/poweroff (SOLVED)
Postby EnforcerZhukov » 02 Apr 2017, 12:09
Hi, just installed today RuneAudio v0.3 on my Raspberry Pi 1 (Model B) -the latest RA release for this RPI-, and is really cool. Tried Volumio on the past but the WebUI is quite laggy, while RuneAudio WebUI is smoother.
Anyway, I've got this problem: I change the network settings on the WebUI, to a static IP... and it changes OK, everything is ok, the new IP and everything. But when I reboot, or power off and then start again the RPI, then the network stops working! I can't access RuneAudio anymore. If I run ifconfig on the RPI itself, eth0 has got no IP. Pings to external or LAN IPs don't work (gives a Network not reachable error).
Tried searching this error but found nobody else with it. Somebody know what is going on?
Thanks in advance!
Solved with the steps at the end of this article: http://www.runeaudio.com/documentation/ ... tly-builds
EnforcerZhukov
Re: RuneAudio looses static IP after reboot/poweroff
Postby brucehuang55 » 02 Apr 2017, 15:31
I've been using V0.3 on my Raspberry 3B for two months and I'm really happy with it. Mostly I use Wifi to access UI by ipad or iphone. However, your issue (static IP changes for both Wifi and wire) also happened to me around 4~5 times. When I can't connect the UI, I need to connect by wire and check my PC for the "new" static IP, then input it in ipad/iphone and find back UI. I really also would like to know the reason why. Thanks.
brucehuang55
Postby EnforcerZhukov » 02 Apr 2017, 16:51
EnforcerZhukov
Postby hondagx35 » 02 Apr 2017, 22:29
Hi EnforcerZhukov,
please try to update to our "Nightly Builds".
Postby hondagx35 » 02 Apr 2017, 22:31
Postby brucehuang55 » 03 Apr 2017, 08:53
Currently it's no problem, but it really happened many times that the connected IP of UI changed for unknown reasons. Please help check, thanks.
https://pastebin.com/6Mn8ZGYq
brucehuang55
Postby hondagx35 » 03 Apr 2017, 10:24
Postby EnforcerZhukov » 03 Apr 2017, 20:42
EnforcerZhukov
