RuneAudio not reacting after DAC shutdown
Re: RuneAudio not reacting after DAC shutdown
Postby PeteB » 03 Jun 2016, 04:21
Hi Stefan,
So far I cannot duplicate this behavior. I left my dac connected, and turned off for an hour once, and about 1 hr 15 minutes a second time.
On the other hand, some of the things I can repeat every time, other people do not have at all, so perhaps this is not so unique.
I will try again this weekend. It is an easy test, basically I just have to turn the dac off and leave the Pi on.
Pete
Postby skfly » 03 Jun 2016, 08:48
Hi Pete,
first let me thank you for your efforts, even if you weren't able to reproduce the malfunction. I really hope we can solve this issue, as I really (!) like RuneAudio as a playback device!
Is there any debug information I can retrieve via SSH that might help you narrowing down the problem? I would need precise instructions though, as I'm not a Linux expert.
Thanks,
Stefan
skfly
Postby hondagx35 » 03 Jun 2016, 11:41
Postby skfly » 03 Jun 2016, 21:09
skfly
Postby hondagx35 » 03 Jun 2016, 21:53
Hi Stefan,
this is very strange.
Please also check these services:
- rune_PL_wrk
- php-fpm
- nginx
Postby PeteB » 04 Jun 2016, 04:13
Stefan,
just for the record, I cannot duplicate this. I tried again, and I can make a crash happen, where the Pi is not responsive at all, but not the behavior you are seeing, sorry. In any case this is in better hands with Frank, ;)
Pete
Postby skfly » 08 Jun 2016, 18:34
I've tried the additional services, but they also appear to be up and running while RuneAudio itself isn't responding. Well, "kind of not responding", as I figured out by now, as 10-15 minutes after my initial request everything works fine again, without a restart.
Might this something have to do with the additional HID device which seems to be part of my amp's DAC (see the log from previous post)?
skfly
Postby Luc45 » 29 Aug 2017, 15:15
Hello, I am new to RuneAudio and generally very much taken with it. However, I experience the same problem described in this thread. I run RuneAudio on a Raspberry Pi 3 with a Pioneer A-70 Amp/USB-DAC. Whenever I shut down and power-on the Amp or switch input sources RuneAudio malfunctions. The only workaround for this is to restart the RPi3 once the DAC is active, it seems. Is there any solution to this by now?
Luc45
