Runeaudio+Odroid C+ Freezing Problem
ODROID related support
Postby bongieto » 17 Feb 2016, 01:27
I got an Odroid C+ installed with the latest Rune Audio Build. However, it keeps freezing. Sometimes just a few minutes after booting and sometimes after a few hours. It is just unreliable. It just stop responding and the music stops too. I reimaged it multiple times already to no avail. Any suggestion? Thanks!
bongieto
Re: Runeaudio+Odroid C+ Freezing Problem
Postby The Reverend » 17 Feb 2016, 12:29
Hmmm,
0.3 is running flawless here. What size is your poiwer supply and how many periphals have you got attached?
The Reverend
Postby bongieto » 18 Feb 2016, 03:34
I only have my USB dac (TEAC UD501) plus a single USB flash drive. I'm connected to the network via ethernet jack. I am trying to isolate the issue maybe its not compatible with the DAC? I'll do some more observation hopefully I can identify whats causing this issue. Thanks
bongieto
Postby obee » 18 Feb 2016, 07:40
Do you see any error?
you can see if you connect an HDMI cable to monitor.
obee
Postby edgeyim » 02 Mar 2016, 10:59
I got freezing problem when C1+ access any music file on my NAS.
I can browser NAS folder and add files to play list, but C1+ freezing at once when it start to play...
And I need to power cycle to make it online again.
Any idea appreciate.
edgeyim
Postby ncooee » 24 Mar 2016, 09:08
This is the problem of the bogus Teac USB interface in UD-501/UD-503. Freezing happens when frequency of the sound files changes. This has already been been fixed in the mainline kernel.
https://github.com/raspberrypi/linux/co ... 6a453a31c4
You need at least kernel 3.10.98 (Odroid has 3.10.80).
By the way,t he new Raspberry Pi2/3 includes that quirk and the UD-503 runs for days without freezing.
ncooee
Return to ODROID
