Postby rern » 01 Oct 2019, 02:06
Postby cmh714 » 01 Oct 2019, 02:24
Postby rern » 01 Oct 2019, 03:05
@cmh714,
There's the System Volume Information directory so it means your USB is not ext4 format. Backup the current data and reformat it to ext4 and try again.
Postby cmh714 » 01 Oct 2019, 03:12
Postby cmh714 » 01 Oct 2019, 05:06
@rern tell me where to send you a beer :) damn id10t errors....
All good now except for a small annoyance....every 10 seconds or so I get a pop up in the left bottom corner telling me my Library finished updating....very annoying.
THANKS!!!
Postby AndyF » 01 Oct 2019, 08:12
Hi rern,
today an update was found after reboot - and this fixes the Update-notification and playlist-bug. Only lyrics-thing is still there.
Thanks!
regards, Andy
AndyF
Postby klassikmann » 01 Oct 2019, 08:17
Minor issue:
"GPIO" is (again) part of the main menu, although the GPIO-addon is not installed.
klassikmann
klassikmann
Postby cmh714 » 01 Oct 2019, 17:06
OK, fresh flash, fresh format...installed/updated Addons....havent done anything else and still keep getting the Library Update Done ribbon popping up every 5 or so seconds. The only "source" is the USB as I have not done nfs...
so why the heck does the pop-up keep showing? its more that super annoying :)
Postby belgarath0815 » 01 Oct 2019, 19:44
really like the new version, thanks a lot!
small bug:
local browser screen off: you put in minutes (which are saved as seconds), but on a reboot the value is not converted back properly when loading it again and the seconds are used as minutes. So a 1 minute timeout turns into a 60 minutes timeout.
belgarath0815
Postby rern » 02 Oct 2019, 06:13
