Postby klassikmann » 05 Oct 2019, 14:26
klassikmann
Postby AndyF » 05 Oct 2019, 18:49
AndyF
Postby rern » 06 Oct 2019, 11:24
Update 20191006
- Fix - Update notification when Auto update enabled.
- Fix - System page layout on small screen.
Postby klassikmann » 06 Oct 2019, 12:02
klassikmann
Postby cmh714 » 06 Oct 2019, 21:14
@rern, small request maybe....I personally use BOTH Consume mode and Repeat mode to achieve what I want. Currently, you have it so enabling Consume, disables Repeat and vice a versa. Wondering if you might change that behavior?
For context if it matters, I always have several webradios in my Queue and then add other music at the bottom, so that when it finishes, it goes back to the start and radio stations.....
Regardless, I take care of it at the commandline.....THANKS!!!!!
Postby Toube » 07 Oct 2019, 10:57
Hi Rern,
I tried to get the 1.2 version up and running but no luck.
Do I need an additional USB thumb drive attached to the Rpi to get up and running?
Nope no difference using USB thumbdrive.
My problem is that I'm not seeing any menus anywhere so I cant access anything.
I can use the /addons.php or /indexsettings.php but that doesn't help... I can't get the menus to appear.
Anyone experienced the same phenomenon with 1.2 version?
Regards,
Toube
Toube
Postby rern » 07 Oct 2019, 12:48
Toube,
The USB drive is a MUST.
You can't just plug in the drive after initial boot was run. It has to be plugged in for initial setup on very first boot.
Reflash the SD card and try again.
Postby Toube » 07 Oct 2019, 12:52
Toube
Postby Toube » 07 Oct 2019, 14:02
Hi Rern,
an update. I got it working, a few questions:
- Does the thumbdrive need to be there all the time?
- I can't enable or disable features in System, Network, MPD or any other pages.
-Toube
Toube
Postby Alien8 » 07 Oct 2019, 15:38
Alien8
Users browsing this forum: Bing [Bot] and 3 guests
