Postby Alien8 » 08 Oct 2019, 15:52
Alien8
Postby tixs » 08 Oct 2019, 19:45
Some earlier bugs seem to still exist on a fresh installation of Re1.2 (with all updates as of today applied):
- WLAN does not work for me. (My WLAN Router is not even shown, even though it sits in just 1 m distance and all other WiFi devices connect fine and SSID is not hidden). Setup of a static IP also fails. (I use a Raspberry Pi 3 B Rev. 1.2 with the standard Edimax WiFi dongle, onboard devices are switched of by removing the # in the config.txt in root folder immediately after writing the image (Re1.2) to the SD card. That approach worked well with the RuneAudio versions prior to Re edition.)
- Change of device name still shows no effect. Player remains to be browser accessible via runeaudio.local only but not via the changed player name as is shown in the System menu.
- Volume knob magically moves up or down by one notch from time to time without anything being touched. (I use hardware control of a HifiBerry DAC.)
tixs
Postby kiddy » 08 Oct 2019, 21:09
kiddy
Postby Alien8 » 09 Oct 2019, 09:10
Alien8
Postby R101 » 09 Oct 2019, 10:58
Postby AndyF » 09 Oct 2019, 17:04
@kiddy
What about permissions in /srv/http/data folder? Do you have an ext4-formatted USB-Stick?
Andy
AndyF
Postby kiddy » 09 Oct 2019, 18:24
kiddy
Postby Toube » 09 Oct 2019, 18:47
I can't get the 1.2 to install on my Raspberry Pi 3 Model B Plus Rev 1.3.
On the 3 Model B without the plus it installs.
I get the same problem I don't see any menu.
I have a ext4 formatted USB attached before I power on the Pi.
I redownloaded image and reimaged using Win32 disk imager. Still no luck. If I go to system page using url it will not show the runeversion .. it shows kernel version etc. but the runeversion is empty or only the rune icon is there.
If I go to the add-ons page using url and update the version to 17 of September and then go to the front page.. it will only show me a plus icon so the UI get totally messed up.
The difference between my plus on non plus version is that on the plus version I have the Allo digione signature inside and on the non plus I'm using a USB dac.
Any ideas?
-Toube
Toube
Postby tixs » 09 Oct 2019, 20:04
tixs
Postby rern » 10 Oct 2019, 06:18
@tixs,
Since you don't like virtually everything about RuneAudio+R e1 and you've tried it, you should stay with your current version.
Users browsing this forum: Majestic-12 [Bot] and 55 guests
