Postby rern » 15 Oct 2019, 05:02
Postby rern » 16 Oct 2019, 06:04
Postby J4K » 20 Oct 2019, 19:14
I'm using: rpi3b
IqAudio+ dac
RuneAudio+R e1
usb Stick formatted in EXT4
seperate powered usb ssd drive
Having used RE1 For about a week, I'm quite impressed, very stable, for me.
However, in the Addons menu when I click the update button, I get this:
Install new files ...
/srv/http/addons.php
/srv/http/addonsbash.php
/srv/http/addonsupdate.sh
/srv/http/assets/css/desktop.css
/srv/http/assets/css/indexsettings.css
/srv/http/assets/css/info.css
/srv/http/assets/css/main.css
/srv/http/assets/css/selectric.css
/srv/http/assets/js/context.js
/srv/http/assets/js/function.js
/srv/http/assets/js/lyrics.js
/srv/http/assets/js/main.js
/srv/http/assets/js/mpd.js
/srv/http/assets/js/network.js
/srv/http/assets/js/sources.js
/srv/http/assets/js/system.js
/srv/http/assets/js/vendor/jquery.selectric.min.js
/srv/http/commands.php
/srv/http/getcover.sh
/srv/http/index.php
/srv/http/indexbody.php
/srv/http/indexsettings.php
/srv/http/lyrics.php
/srv/http/lyricssave.php
/srv/http/settings/credits.php
/srv/http/settings/mpd.php
/srv/http/settings/network.php
/srv/http/settings/sources.php
/srv/http/settings/sourcesmount.sh
/srv/http/settings/system.php
/srv/http/settings/systemdata.sh
./install.sh: line 91: unexpected EOF while looking for matching `"'
./install.sh: line 92: syntax error: unexpected end of file
And don't know if it is related to not being able to update, I can no longer map to the RPI3B usb drive in Win 10.
RuneAudio Shows in Media Streaming Options.
Do I need to install/Alter somthing to get the rpi3b to show up?
Keep up the great work :)
J
J4K
Postby cmh714 » 21 Oct 2019, 20:40
@rern - not sure if I saw this posted previously....if you load up a playlist into the queue, and add/subtract files and try to save it as the same name, you get the message that a Playlist with that name exists already instead of being asked if you want to overwrite, so you need to save it as a new name, delete the old playlist and rename the new one to what you want. Maybe not such a "bug" but a small hassle, although it does prevent you from overwriting by accident.
Second, is there a way to update the Coverart?? I cant seem to figure it out... :)
I added more, but they arent showing up.
TIA
Postby rern » 22 Oct 2019, 05:36
Postby rern » 22 Oct 2019, 09:23
Postby cmh714 » 22 Oct 2019, 23:45
Postby rern » 23 Oct 2019, 16:13
Postby cmh714 » 23 Oct 2019, 19:05
Postby aldebert » 03 Nov 2019, 17:41
Hi rern,
i've installed the last version of Re1
first i had some problems because i didn't see the need of an extra ext4 partition
i have not tried everything but I find it very nice ,
one thing missing for me is the screensaver for local browser
on 0.5 there was an option to switch off the screen (in the power menu)
is there a way to switch off the screen?
aldebert
