Postby rern » 04 Nov 2019, 09:45
Postby Petestorms » 06 Nov 2019, 09:42
Hello everyone,
I develop a small streamer for a visually impaired friend of mine. After trying different software packages (Volumio, Moode), Runeaudio has turned out to be the most capable software for this. I use infrared remote via LIRC, combined with speech synthesys feedback. Via the IR remote my friend can choose predefined playlists, tracks etc. Through text to speech (espeak package) he can hear track being played. Works nicely!
I used Runeaudio beta 0.5 succesfully for this setup on Raspberry Pi 2B. Controlling MPD directly through Lirc is what I needed. There is one thing that did not work, my Tp-Link Archer T2U wifi adapter is not supported. I found out that driver is included from kernel 4.19.
Then I came this Re1 software. Wifi adapter works! But... playlists are not saved. It says it does in the webinterface, but when I select the folder icon in the queue, nothings shows up. Also /var/lib/mpd/playlists stays empty.
I reinstalled, did full update through addons menu, but is just does not work. I install through the Balene Etcher app on Mac to SD card, just like I always did with other software, even tried Pi Baker burning sw on Mac, same result.
Any hints?
Version used is RuneAudio+R_e1.2.img.xz 29/9/19
What is perhaps interesting is that when I chose update in the Addons menu, some errors were shown concerning file ownership in the /mnt/USB/... directories, including ..../playlists. Could it have anything to do with that?
Petestorms
Postby AndyF » 06 Nov 2019, 18:44
Hi Petestorms,
is your USB-Stick formatted as EXT4? Extra directories need Linux's ownership handling to work properly.
But I think you should wait for next version - many issues are gone there ...
Regards, Andy
AndyF
Postby Petestorms » 06 Nov 2019, 20:40
Hi Andy,
USB drive is formatted as FAT.
I will wait for the new release, and use B0.5 in the meantime ;)
Petestorms
Re: RuneAudio+R e2 - An improved version of RuneAudio
Postby rern » 09 Nov 2019, 09:07
Released!
Get it from the .
- Now support all versions of Raspberry Pi: Zero, 1, 2, 3 and 4.
- 3+ not yet available but can be built with:
- Built from Arch Linux Arm latest releases.
- Upgrade kernel and all packages to the latest.
- Easily pre-configure Wi-Fi connection (headless mode)
- USB drive is not required any more. But if it's a hard drive RuneAudio can run directly on it with the DIY procedure.
- System-wide upgradeable: pacman -Syu can be done without broken the system.
Postby AndyF » 09 Nov 2019, 10:59
Hi rern,
thanks for your new version - works like a charm out of the box (RPi 3 with HifiBerry DAC+)!
"old" data-folder was restored correctly via copy+runerestore.sh
-> IMHO best version so far.
regards, Andy
AndyF
Postby ceejayemm » 09 Nov 2019, 12:53
Hi Rern
Thanks for this new release, works for me out of the box too on RPi 3 with AudIODAC+. The only suggestion I would make would be to clarify the instructions needed to copy the existing setting etc from the USB drive. For me this was:
cp -r /mnt/MPD/USB/DataDisk/* /srv/http/data
(as I had named my USB drive 'DataDisk' when formating it to Ext4).
Many thanks
Chris
ceejayemm
Postby Leobo71 » 10 Nov 2019, 07:41
Hi All.
Great job @Rern. I have Pi Zero whit Justboom DAC whit new release. Work Fine and look nice. I have little problem config my audio I2's card and AirPlay . System reboot and Airplay ,audio card are here.
Version 0.5b Janui ist simple and work fantastic Version R e2 Rern look great work nice.
Big thanks for Janui and Rern. RuneAudio ist my best player on raspi. Sound ist fantastic.
Leobo71
Postby Beelzebassie » 10 Nov 2019, 16:28
Excellent work!
Encountered a few little quirks, nothing major. Will report them after I'm done playing around.
Beelzebassie
Postby Leobo71 » 10 Nov 2019, 17:13
Pi Zero Re2, Airplay only works if player is in stop mode. 0.5b version switches automatically. i2's sound card selection is a bit complicated.
Leobo71
