Re: RuneAudio+R e2 - An improved version of RuneAudio
Postby AndyF » 11 Nov 2019, 19:56
@rern
What does "URL by name" mean at system-settings? I can´t disable them and I have no idea, what it is for ...
Thanks for your support!
regards, Andy
AndyF
Postby s.k. » 11 Nov 2019, 20:41
@ Rern
It is very strange.
In both versions – build from scratch and ready image – the settings are not stored.
After rebooting I have again the default ones.
What am I doing wrong?
Any idea?
Stavros
s.k.
Postby s.k. » 12 Nov 2019, 07:43
Further info.
I try to change to static IP (192.168.1.101)
It takes some tries but finally:
I reboot the raspberry through the web interface.
Here is the new network info:
The curious thing is that although the eth0 files have the correct info, it doesn’t apply it:
Any thoughts ?
Stavros
s.k.
Postby klassikmann » 12 Nov 2019, 09:47
FWIW: Re2 signalled an update today:
2nd try succeeded.
klassikmann
klassikmann
Postby vennesch » 12 Nov 2019, 10:45
Thank you so much for this version rern! Best one so far!
Few small bugs though:
In add ons menu
Expand partition fails to download the install file
Update for RU E2.0 succeeds but stays available in the add ons menu
Keep up the good work!
vennesch
Postby rern » 12 Nov 2019, 12:39
Postby PierreG64 » 12 Nov 2019, 13:14
Thank you very much Rern for this release: RuneAudio+R_e2-RPi2-3
It is functional and all my hardware (Nas NFS, Dac USB Teac) has been recognized unlike the previous version.
I installed it yesterday.
I had only one problem, extend the partition with the addons. So I went through the command line method and "putty" explained on the site.
From there, everything worked.
I do not know anything about programming to help, I enjoy the work of people like you who share what they do.
Thanks again.
Pierre
PierreG64
Postby PierreG64 » 14 Nov 2019, 23:45
Hello Rern,
I can not read the files in ape format. should I add something for that?
if someone has the solution ...
Thanks!
Pierre
PierreG64
Postby rern » 15 Nov 2019, 03:24
Postby s.k. » 16 Nov 2019, 18:39
Hi rern,
- Is it possible to mass import webradios ?
- Is it possible to modify / delete a NAS share ?
Stavros
s.k.
