Re: RuneAudio+R e2 - An improved version of RuneAudio
Postby AndyF » 17 Nov 2019, 11:20
Hi Stavros,
to import webradios, there´s an Import-Addon for m3u and pls-files.
Modify a share is IMHO not possible at the moment.
regards, Andy
AndyF
Postby s.k. » 17 Nov 2019, 12:36
s.k.
Postby AndyF » 17 Nov 2019, 12:54
Hi stavros,
it seems to be a bug at "Sources"-menu. In previous versions, after unmount there was a "-"-Symbol to remove the source.
@rern
After unmount, share is hidden in menu after reload - but it keeps in /etc/fstab. After reboot, share is back again.
regards, Andy
AndyF
Postby rern » 18 Nov 2019, 02:28
Postby AndyF » 18 Nov 2019, 06:06
AndyF
Postby rern » 21 Nov 2019, 01:11
Full Update
Postby s.k. » 26 Nov 2019, 05:32
After a clean install of the img “RuneAudio+R_e2-RPi2-3” on a raspberry Pi2, I was able to perform a full update (pacman –Syu).
The update finished successfully, without errors and included also the latest kernel (4.19.85-1).
Great job rern !
Thank a lot – once again.
Stavros
s.k.
Postby Embehu » 27 Nov 2019, 13:24
Embehu
Postby Embehu » 28 Nov 2019, 00:35
Hi all,
I’m using pi 3b with runeaudio r+, just changed to this version from the one in the home page. I got an issue that I couldn’t know how to figure out.
For the 0.3 in home page, it automatically recognise and go to web ui screen (waveshare 3.5” ips)
But when I installed R+, no matter what I tried, it just getting stuck with Runeaudio logo instead of Web ui as normal. ( I don’t use touch just display only)
Embehu
Postby rern » 29 Nov 2019, 03:38
