Re: RuneAudio+R e2 - An improved version of RuneAudio
Postby Ripa » 29 Nov 2019, 17:19
i have now Rune the lastest version, it's perfect. and still paying also with Moode.
i have change some things like the setting of the wifi with a password.
that i cannot change in Moode audio why i dont know
music with rune
Ripa
Postby R101 » 29 Nov 2019, 22:49
Hi rern,
I just had another try of RuneAudio+R and, after adding the wpa_supplicant.conf file, I got it connected to my hidden SSID at last.
Putting a working wifi file in /usr/netctl did not work, and it is not possible to use a local touch screen to configure the network because there is no virtual keyboard. The AP does not automatically restart if Rune fails to connect.
I could not get anything to update until until I ranked the package servers. After expanding the partition, it still reports the original size. The local screen settings icon stopped functioning after it failed to save the setting, so I modified config.txt to get the local 7" display the right way up.
The only playback tools I have ticked are Top-Bottom Bars and Bars On Small Screen. Would it be possible to move the track-and-time text down the screen and give it larger type? (Enlarged top and bottom bars would also be a help for those with large fingers and poor eyesight.) I am happy to experiment with this if you can point me to the right area.
This version seems to be progressing well. Thanks for all your work.
Postby frankz » 03 Dec 2019, 16:25
NON riesco ad accedere alla rete wifi se nella password utilizzo caratteri come: £ $ % & , perchè, nella versione vecchia funzionava.
frankz
Postby Hellgier » 21 Dec 2019, 00:43
Thank you, rern!
I'm delirious with joy to know that Rune has continuation! It is after all the best system for music I know (except maybe Rockbox <3 )
Have you come across this?
https://makingstuffwork.net/technology/ ... pberry-pi/
That may be helpful.
Hellgier
Postby kirx » 21 Dec 2019, 19:46
@rern
> (Tested on RPi 3B - please report success runs on other models.)
No critical installation problems on RPi3B+ / 5inch Resistive Touch Screen XPT2046 / 8x TDA1387 USB DAC
Wired network setup/NAS setup/Library management runs smoothly, Wi-Fi setup still requires to describe in detail all the authentication parameters (in the same way as we discussed 2-3 months ago).
Overall, this release (RuneAudio+R e2) is simply great, many thanks & a lot of respect! :)
kirx
Postby bnilsson » 28 Dec 2019, 12:04
Great job!
However, the RuneAudio app for Android is MUCH slower when connecting to this new version. Ay idea why?
Can this be improved?
BN
RP3+ HifiBerry DigiPro
bnilsson
Postby AndyF » 28 Dec 2019, 12:36
RuneAudio-App is rather old and IMHO untested with +R e2. I'm using RuneAudio as WebApp via Chrome ("send to Homescreen"). Works very fine here.
Regards, Andy
AndyF
Postby bnilsson » 28 Dec 2019, 17:04
The new UpnP settings dialog contains entries for Qobuz, Tidal, Google Music, etc.
What are these settings for?
If I fill in my streaming account info for Qobuz, the UpnP device disappears from my network.
Else from that, I see no added features on the GUI. Where should my Qobuz appear?
BN
bnilsson
Postby rern » 31 Dec 2019, 18:15
Postby bnilsson » 01 Jan 2020, 12:48
bnilsson
