Re: RuneAudio+R e2 - An improved version of RuneAudio
Postby R101 » 20 Jan 2020, 12:05
Stablgr,
I think you might need display_rotate=2 for HDMI. I am pretty sure that lcd_rotate only affects the lcd port.
Postby stablgr » 21 Jan 2020, 01:57
Doh! That makes so much more sense. Thanks R101. Works like a charm now.
stablgr
Postby rern » 21 Jan 2020, 11:47
Update 20200120
Fixed - Auto update in MPD settings
Fixed - Bluetooth, Wi-Fi and Browser on RPi in System settings
Fixed - Add 1st Webradio not show unless refresh
Improved - Playback interface now responses without delay
Postby klassikmann » 21 Jan 2020, 23:30
klassikmann
Postby chrisryburn » 22 Jan 2020, 07:16
After trying an early version on my Raspberry Pi 2B with my mojo DAC, which worked well. Subsequent versions didn't work well, so I gave up and used another product.
I've just tried again, downloading, running update successfully, but finding it won't read my USB drive. It finds it, but the light is red and it won't mount.
/mnt/MPD/USB//dev/sda2 contains a hfsplus file system labelled 'Music'.
Drive read fine by 0.5 version
Appreciate any help
chrisryburn
Postby eggshell » 23 Jan 2020, 03:56
I have RuneAudio+Re2, MoodeAudio and Volumio on three different microSD cards. I use a Pi3B+ and Allo Boss DAC. I have to say that I always come back to Rune as it sounds the best. The difference is subtle, but I find myself tapping my foot to the music way more often when using Rune.
I also like the interface the best. Great job Rern. Thanks for your efforts.
There is one thing that I was hoping to get some help with. Is there a way for the MPD scan to ignore the @eaDir files? It makes everything take longer and the CoverArt scan gets bogged down with them as well. I am using a Synology NAS for my music storage.
Andreas
eggshell
Postby klassikmann » 23 Jan 2020, 10:56
klassikmann
Postby AndyF » 23 Jan 2020, 12:05
... and an additional info - folders can be excluded via context-menu at library on Re2 (it creates an .mpdignore-file).
Andy
AndyF
Postby klassikmann » 23 Jan 2020, 17:22
klassikmann
Postby rern » 24 Jan 2020, 05:18
