Re: RuneAudio+R e2 - An improved version of RuneAudio
Postby proteus » 26 Jan 2020, 21:43
Hi Rern, how can we get a 3.5" LCD working? Were do i put the LCD driver?
Paul
proteus
Postby J4K » 26 Jan 2020, 22:05
J4K
Postby R101 » 27 Jan 2020, 11:29
J4K,
I had a problem connecting to a network drive with +R which had never occurred with previous versions. It was because the drive firmware is not compatible with the new samba version, but adding vers=2 to the options field in Networks setup fixed it.
Could your problem be due to a similar incompatibility?
Postby J4K » 27 Jan 2020, 13:11
Hello Everyone,
Just a Quick update, after much google fu, I believe Samba was missing from my install, (I couldn't get samba-rune to install). Once I installed this, rune appeared in device manager (greyed out), and also in devices and Printers (greyed out).
I then downloaded WinSCP and was able to alter some samba files, rebooted the pi and rune now shows up in Mapping options, and I can transfer files to the usb drive.
Thanx Everyone
J
J4K
Postby rern » 27 Jan 2020, 15:30
Postby R101 » 27 Jan 2020, 19:17
Thanks for the updates, rern. This is now my daily-use version.
Feature requests:
Can we have the next/previous icons back on the top bar, where relevant, please?
Also, under Library Tools, can the Single Tap Song be add>replace>play - at least on the Webradio page, but preferably always?
Postby AndyF » 28 Jan 2020, 06:43
AndyF
Postby rern » 28 Jan 2020, 08:15
Postby J4K » 28 Jan 2020, 18:38
Hello Everyone,
Back Again :)
Another Update, All the Stuff I tried worked for a short time, and then corrupted. Doh!
Fresh install and Rerns latest Update Actually got Rune showing up in drive mapping, But the pi3 would not accept the connection.
OK it's Testing me.
Then I had a Brain Fart, forget wifi, try the ethernet cable. connected the cable and rebooted the pi3, and The drive Mapped straight away.
Disconnected the ethernet cable and rebooted the pi3 Again to test with wifi, and the drive was still there. :)
Moral: KISS
RuneAudio+R e2 is now my goto player, I'll keep rune4 on a seperate card for emergencies.
Now for a couple of questions if you will indulge me. :)
I really like the VU meter when a radio station is playing, it's animated on my laptop screen, but not on the rpi 7" screen, is this normal?
And now that I'm getting to grips with WinSCP, if a person wanted to tweak the sort order in the library, what files would I be looking at?
Thanx to everyone for their help.
J
J4K
Postby rern » 29 Jan 2020, 04:40
Users browsing this forum: No registered users and 48 guests
