Postby Alien8 » 29 Aug 2019, 11:10
I've been trying to get your version up and running but in my part of the universe, it just doesn't seem to work out of the box.
Due to space constrictions I'd like to use the access point for initial wireless network config.
Yet no matter what I try, there is no way any of my wireless devices can connect to the AP network... I can 'see' it just fine
I also tried a lan cable into a simple switch, connected to my pc's lan port (I have to rely on wireless for internet access on my pc as well), also a negative
I can see the device is up and running by connecting a screen to it but even with the help of a local keyboard and mouse, there is no way to be able to even access the correct page to scan for and input the wifi details.
I also tried to install from janui's version but that no longer works as well
so a genuine 'help please ?' is in order :|
RPi3B+ RuneAudio+Re1 --> runs but cannot be configured
RPI3B+ RuneAudio v 0.5b11 -> does run and can be configured, no addons/enhancements
on another note : I've noticed the image referred to in the first post of this thread has been uploaded from thailand ? I believe Rern is based in Holland ?
D
Alien8
Postby chrisryburn » 29 Aug 2019, 14:55
Hi Rern, You asked if I could post results from:
lsusb
aplay -l
mpc outputs
Here are results:
root@runeaudio04:~ # lsusb
Bus 001 Device 004: ID 148f:5370 Ralink Technology, Corp. RT5370 Wireless Adapter
Bus 001 Device 006: ID 1058:1023 Western Digital Technologies, Inc. Elements SE Portable (WDBABV)
Bus 001 Device 003: ID 0424:ec00 Standard Microsystems Corp. SMSC9512/9514 Fast Ethernet Adapter
Bus 001 Device 002: ID 0424:9514 Standard Microsystems Corp. SMC9514 Hub
Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
root@runeaudio04:~ # aplay -l
Subdevices: 7/7
Subdevice #0: subdevice #0
Subdevice #1: subdevice #1
Subdevice #2: subdevice #2
Subdevice #3: subdevice #3
Subdevice #4: subdevice #4
Subdevice #5: subdevice #5
Subdevice #6: subdevice #6
Subdevices: 1/1
chrisryburn
Postby chrisryburn » 29 Aug 2019, 14:58
Rern,
The rest of the results:
root@runeaudio04:~ # mpc outputs
Output 1 (bcm2835 ALSA_1) is disabled
allowed_formats=""
dop="0"
Output 2 (bcm2835 ALSA_2) is disabled
allowed_formats=""
dop="0"
Output 3 (Mojo) is enabled
allowed_formats=""
dop="0"
root@runeaudio04:~ # installurl=$( grep 'RuneAudio_Addons/raw/master/install.sh' /srv/http/addonslist.php | cut -d "'" -f 4 )
root@runeaudio04:~ # echo $installurl
https://github.com/rern/RuneAudio_Addon ... install.sh
root@runeaudio04:~ # wget -N --no-check-certificate $( dirname $installurl )/srv/http/addonslist.php -P /srv/http
--2019-08-23 20:44:25-- https://github.com/rern/RuneAudio_Addon ... nslist.php
Loaded CA certificate '/etc/ssl/certs/ca-certificates.crt'
Resolving github.com (github.com)... failed: Name or service not known.
wget: unable to resolve host address ‘github.com’
chrisryburn
Postby Igor » 30 Aug 2019, 18:16
Raspberry pi 3b - hifiberry dac plus pro
Igor
Postby R101 » 01 Sep 2019, 13:03
Hi rern,
I am still using 0.4b, which serves my needs, but a non-technical friend using 0.3 asked if I could help with an update. The idea was for me to set up an SD card which he could just plug in and use.
Updating to the +R e1 enhanced UI on 0.4 resulted in no UI at all, so I gave 0.5 +R e1 a go.
The AP lit up, but I could not connect with DHCP. If I used a fixed IP 192.168.5.2, I could connect, but could not communicate, rather as if the AP was using WEP protocol.
I gave up on the AP and tried a wired connection. The wifi setup does not allow for a hidden SSID, and just copying a config file into netctl did not work.
So, is the UIe now only available as the 0.5 RuneAudio+R e1 package, or should Addons still be an installable option for 0.4?
Postby rern » 01 Sep 2019, 14:30
Postby R101 » 01 Sep 2019, 16:17
Thanks for the reply rern.
One other thing: I have a Webradio folder, but I am not sure where this needs to be copied to now. Will it still be imported from /mnt/MPD?
Postby Vhond » 02 Sep 2019, 16:56
About bitperfect: RuneAudio+R e1 includes an option to select MPD bitperfect setting.
Do you know what this exactly means (isn't this possible as option using the Rune 0.5b version)?
Vhond
Postby krpepe » 03 Sep 2019, 12:34
krpepe
Postby tio_cristobal » 05 Sep 2019, 04:08
Hi Rern,
With your last available version "R_e1", I succeed to have control buttons and LCD working again together (I am using RuneAudioLCDMod, with some tweeks works great).
But... I am curious and would like to know how to solve the addons server not available message..
I have seen in Github, your RuneAudio+R_e1 page and observe when downloading the master.zip, it only "weight 66kB", far from the Gigas of the original image. It looks like you upload only the changes? Right?
How to proceed to include those modificacions in the Pi3+ since hss session if my observacion is correct?
Best regards, Chris
tio_cristobal
