Postby Vhond » 05 Sep 2019, 09:48
Vhond
Postby rern » 06 Sep 2019, 08:24
Postby rern » 06 Sep 2019, 14:23
Released!
RuneAudio+R e1.1
- Fix Addons server not available.
- Fix RPi access point not working on startup.
- Improve MPD and Network settings.
- Upgrade some packages.
- General improvements and fixes.
- On RPi connected display, startup option to open Network page for new users.
Download link was updated for the new image in the .
Reflash the new image file will preserve all database and extra directories. (They are stored in USB drive and will be restored back automatically.)
Postby Alien8 » 06 Sep 2019, 16:36
Hi Rern
thanks for the hard work, this release seems a bit better
Testing right now
on RPi2, audiophonics sabre dac amp
local browser crash (Redis server went away...), so no local config
AP doesn't show up even after 10 min wait -->
power kill + repair sd card on linux machine and copying known network config file to /etc/netctl works,
audiophonics ATX shutdown unavailible
'no volume setting' does not retain if you close the MPD setting
configuring for my hard ware, will report after thorough testing
D
Alien8
Postby AndyF » 07 Sep 2019, 05:40
"No volume"-setting bug is here, too. Workaround: Usage of "Disabled"-setting behind selected I2S-module.
AP is no problem on my RPi3.
regards, Andy
AndyF
Postby tixs » 07 Sep 2019, 07:30
A few bugs to report from an initial look at it:
It seems that static IPs are not being saved and not recognized, both for LAN and WiFi. Also no change after reboot or power off.
A change of the Player name seems also to be of no effect. Even though the new name is apparently saved as it is shown furtheron in the Player name field, the player remains to be browser accessible only via "runeaudio.local" but not via its new name which worked fine under 0.5b. It would be helpful to get that option back, especially if one operates several players in the same network.
And a mysterious issue that persisted also with earlier versions of RuneAudio: Sometimes the volume setting magically changes by one notch - without the user doing or touching anything. Why is that? I tried the BitPerfect setting but this does not seem to change anything.
tixs
Postby thedman! » 07 Sep 2019, 09:01
Hi Rern,
Thanks for your hard work, Rune is nice and slick now.
I second the player name bug mentioned above, it says its changed but isn't.
This is the most minor thing: when tapping the wifi network its asks if you want to "Fotget" the network not "Forget". Sorry, but I had to mention it!
Dave.
thedman!
Postby Vhond » 07 Sep 2019, 14:00
Vhond
Postby Alien8 » 09 Sep 2019, 10:14
Alien8
Postby rern » 09 Sep 2019, 16:05
