Postby BVLabs » 10 Sep 2019, 09:22
Hi, guys.
Can someone implant in the distribution RuneAudio drivers for Allo Katana DAC? Many would appreciate it.
Raspberry Pi 3 Model B Rev 1.2
Terra-Berry DAC2+
BVLabs
Postby Alien8 » 10 Sep 2019, 11:45
Alien8
Postby rern » 10 Sep 2019, 12:17
Postby rern » 10 Sep 2019, 12:19
Update 20190912
- Fix: MPD - "No volume" setting bug
- Fix: MPD - "Play on startup" bug
- Fix: Sysyem - URL not changed along with "Player name" setting
- Fix: Network - LAN static IP setting bug
- Fix: Network - Some hidden SSIDs show as blank
- Fix: Sources - Unresponsive while updating Library
- Add: Sources - Scan for available network shares (network neighborhood)
- Add: Library - Context menu - Exclude directory from database (hide non-music directories which appear after MPD update a directory)
- Change: Sources - Move Update button to Sources submenu
Postby Alien8 » 11 Sep 2019, 11:00
Alien8
Postby Toube » 16 Sep 2019, 11:19
Hi Rern,
thanks for a super cool release. Really like it.
I'm using RaspberryPI 3B+ with Allo Digione Signature.
All is working well.
Some small issues, maybe they are already reported but here's my short findings:
- Webradio : Adding a new url but after added the url I cannot access the webradio anymore.. It just keeps showing the Runeaudio loading logo
- Is the Hostname access working like in 04 and 05.. So that instead of using IP-address one could wrote like: hostname.local to access the player?
I can only access it using ip-address.
Thanks.
-Toube
Toube
Postby Toube » 16 Sep 2019, 16:31
Toube
Postby Alien8 » 16 Sep 2019, 19:25
Alien8
Postby PierreG64 » 16 Sep 2019, 22:20
hi rern,
thank you for your hard work. I really like the aesthetic changes of runeaudio.
I encounter some problems. With your first version I couldn't choose my audio output USB (teac UD-501) and I couldn't configure my Nas.
With this new version (e1.1 with updates) my Teac USB is recognized but I still can not configure my NAS while it is very well recognized in runeaudio 0.5b.
Here are my settings for a synology Nas
NFS
ip: 192.168.1.5
Share path: /volume1/music (i have also try with: /volume1/music/)
Options: (nothing in phis part)
I have always: Mount failed
Could you help me please or is this a problem that will be fixed in a future update?
cordially
Pierre
PierreG64
Postby Toube » 17 Sep 2019, 06:32
Toube
Users browsing this forum: Google [Bot] and 16 guests
