Postby Alien8 » 17 Sep 2019, 08:32
Rern is working hard to iron out the bugs, very active on github.
So we'll probably just have to be patient. He's doing this for free....
As said, the update branch solved my nas logon issue for me.
I do admit I keep a spare sd card with the 'old' (sorry @ janui) version just to swap in when it really goes haywire. Though no Rern ui available any more there.
D
Alien8
Postby Toube » 17 Sep 2019, 08:40
Toube
Postby rern » 17 Sep 2019, 11:45
Postby rern » 17 Sep 2019, 12:03
Toube and Pierre,
- Open /etc/fstab file.
- Remove lines which contain IP address, something like //192.168. ...
- Settings > Sources > Tap to start scanning ... (instead of the plus/add button.)
- Select one after scanning finished which will populate input boxes for you.
- Fill in user and password if set.
If the update still didn't help your NAS mount issue, post your /etc/fstab file.
Postby Toube » 17 Sep 2019, 12:24
Hi Rern,
Super. Will try it out later today. Thank you for your hard work.
Regards,
Toube
Toube
Postby rern » 17 Sep 2019, 12:26
Postby Toube » 17 Sep 2019, 15:09
Toube
Postby klassikmann » 17 Sep 2019, 16:24
Update 20190917
"GPIO" is contained in the main menu, but the corresponding addon is not installed.
klassikmann
klassikmann
Postby PierreG64 » 17 Sep 2019, 21:31
Hi Rern,
In addition to your hard work, I thank you for your help and responsiveness.
My Nas is recognized now in NFS. The solution was stupid and had nothing to do with your version of runeaudio.
The solution, which may be useful for someone else, is to enable NFSv4.1 on the synology, not just the base NFS.
Thank you again for your work.
Best regards,
Pierre
PierreG64
Postby klassikmann » 18 Sep 2019, 06:43
klassikmann
