Postby Alien8 » 21 Sep 2019, 07:06
Alien8
Postby rern » 21 Sep 2019, 10:32
Next release
- System-wide upgrade: kernel 4.19.71 and latest version of all packages.
- Fix AirPlay and UPnP bugs
Postby Toube » 22 Sep 2019, 08:05
Toube
Postby R101 » 22 Sep 2019, 20:04
Hi rern,
Is this a release which needs a reinstall, or just an upgrade?
I upgraded but have lost webradio and there is still no onscreen keyboard for the local browser.
The import Webradio addon reports success, but there is nothing in the library. Files in /srv/http/assets/img/webradios are now owned by http, but there are out of date entries which have not been overwritten or deleted by the addon. I can delete everything in the file, but when I run the import addon again the old files reappear in /srv/http/assets/img/webradios, although they are not in /mnt/MPD/Webradio.
Postby cmh714 » 22 Sep 2019, 22:13
Cannot get my NAS to mount via nfs through the UI, was able to mount via command-line....indexing now....
Also the Shares dont show up in the UI under Sources, but I do have everything in the Library...and its gone after a reboot....
I for one need NFS working :)
Maybe this is helpful....
root@runeaudio04:~ # systemctl status rpc-statd.service
● rpc-statd.service - NFS status monitor for NFSv2/3 locking.
Loaded: loaded (/usr/lib/systemd/system/rpc-statd.service; static; vendor preset: disabled)
Active: failed (Result: exit-code) since Sun 2019-09-22 15:00:17 PDT; 50s ago
Process: 2502 ExecStart=/usr/sbin/rpc.statd (code=exited, status=1/FAILURE)
Sep 22 15:00:16 runeaudio systemd[1]: Starting NFS status monitor for NFSv2/3 locking....
Sep 22 15:00:17 runeaudio rpc.statd[2503]: Version 3.1.1 starting
Sep 22 15:00:17 runeaudio rpc.statd[2503]: Flags: TI-RPC
Sep 22 15:00:17 runeaudio rpc.statd[2503]: Running as root. chown /var/lib/nfs to choose different user
Sep 22 15:00:17 runeaudio rpc.statd[2503]: Failed to register (statd, 1, udp): svc_reg() err: RPC: Remote system error - Connection refused
Sep 22 15:00:17 runeaudio rpc.statd[2503]: Failed to register (statd, 1, tcp): svc_reg() err: RPC: Remote system error - Connection refused
Sep 22 15:00:17 runeaudio rpc.statd[2503]: failed to create RPC listeners, exiting
Sep 22 15:00:17 runeaudio systemd[1]: rpc-statd.service: Control process exited, code=exited, status=1/FAILURE
Sep 22 15:00:17 runeaudio systemd[1]: rpc-statd.service: Failed with result 'exit-code'.
Sep 22 15:00:17 runeaudio systemd[1]: Failed to start NFS status monitor for NFSv2/3 locking..
Postby Toube » 23 Sep 2019, 05:47
Toube
Postby Colin » 24 Sep 2019, 17:00
What's the process to build an image (can we find the source and instructions, or better yet, an repeatable build system) somewhere?
I'm asking because I'd love to get more involved in RA development but this seems hard to do as soon as features are not only in the front-end. I forked gearhead's RuneOS repository last year to add repeatability to the build using Ansible, and add a Snapcast feature, but that didn't seem to interest a lot of people : https://github.com/colinleroy/RuneOS
Thanks.
Colin
Postby cmh714 » 26 Sep 2019, 18:25
Postby Toube » 26 Sep 2019, 18:36
Toube
Postby cmh714 » 26 Sep 2019, 19:13
