Postby Toube » 26 Sep 2019, 20:13
Toube
Postby cmh714 » 26 Sep 2019, 20:35
Postby rern » 29 Sep 2019, 10:15
System-wide upgrade
- All latest packages (400+ upgraded)
- Latest kernel 4.19.75
- Now pacman -Syu will not break the system.
- Pesistent database and all settings (Some settings from R+R e1.1 will not be restored.)
- Improve NAS mounts
- Fix AirPlay and UPnP bugs
The image file:
Postby cmh714 » 29 Sep 2019, 15:39
I just noticed that at the top of my Addons page I have this error:   e1.1 Warning: file_put_contents(/srv/http/data/system/version): failed to open stream: No such file or directory in /srv/http/addonslist.php on line 3
And, the Update button is greyed out and I cant update....
As always, appreciate ALL the effort @rern
***EDIT: Fixed the error by creating the file, still have the Updates button greyed out.....
Postby cmh714 » 29 Sep 2019, 16:24
Postby RolandBlaze » 29 Sep 2019, 16:54
RuneAudio+R e6 20201108 
Raspberry Pi 4 Model B Rev 1.
RolandBlaze
Postby klassikmann » 29 Sep 2019, 16:59
I started from scratch with the new image and the thumbdrive containing the 1.1 extra directories. Migration to the new format for the extra directories successful, configuration of 1.2 straight-forward.
klassikmann
klassikmann
Postby cmh714 » 29 Sep 2019, 17:06
hmmm, then interesting that I am having so many issues....I started fresh, used the same USB didnt change anything....but nothing seems to want to "stick" for me. Even changing things in Library Tools, my UI doesnt change and if I go back to the page everything is selected again....
very strange
Postby rern » 29 Sep 2019, 18:10
Postby cmh714 » 29 Sep 2019, 18:58
Appreciate the post @rern...tried several things so wasnt sure on how what you posted would work and it didnt so I started over. New flash, new format of USB, and now I completely f'ed up :) never had so many damn problems before. I do see that the perms after flash dont match what you posted but when I try to chown I am not able to change ownership and so far havent figure it out :)
Probably my biggest problem is that I cant get the MPD Settings to stick on my external DAC, and I never had that issue before.
Going to start clean one more time.....
