Postby cmh714 » 30 Sep 2019, 00:17
So for now I have to give up as this is super frustrating :) Went back to my 1.1 version on my other SD card with the same USB and all is good again....will make some more attempts this week when I feel up to it.
Again, the first issue is why my DAC isnt sticking when I select it....no need to go any further until that gets fixed.
Postby rern » 30 Sep 2019, 08:08
Postby AndyF » 30 Sep 2019, 13:04
Hi rern,
thanks for your update - works fine so far. Most of 1.1-settings were right after reflash. Even MPD-library was fine.
Settings like Color or Bookmark-Order were gone - but not much work to re-set.
I had never problems with NFS-shares - and this version works fine, too.
One issue so far:
- after reboot an update-notification appears, but there is no update available.
regards, Andy
AndyF
Postby cmh714 » 30 Sep 2019, 16:18
Postby Alien8 » 30 Sep 2019, 20:08
@cmh
Are you setting up from local ui (with screen/keyb/mouse on the pi) or from remote ui?
I had some similar issues when doing config from a tablet/remote desktop.
Alien8
Postby cmh714 » 30 Sep 2019, 21:13
Postby AndyF » 30 Sep 2019, 21:41
@cmh
No issues here with config via tablet. What about your USB-Stick? Settings will be saved on USB Stick in "data" folder.
Permissions? (http:http in most cases - mpd:audio for mpd-library)
Filesystem? (Ext4 in my case)
Regards, Andy
AndyF
Postby cmh714 » 30 Sep 2019, 21:56
this is what I ended up with on the USB which was freshly formatted...
root@runeaudio+re1:~ # ls -al /mnt/MPD/USB/
total 20
drwxrwxrwx 4 mpd audio 4096 Sep 29 00:28 .
drwxr-xr-x 6 mpd audio 4096 Sep 5 00:08 ..
drwx------ 2 root audio 4096 Sep 24 22:59 2TB
drwxr-xr-x 4 mpd audio 8192 Dec 31 1969 RUNE
root@runeaudio+re1:~ # ls -al /mnt/MPD/USB/RUNE/
total 28
drwxr-xr-x 4 mpd audio 8192 Dec 31 1969 .
drwxrwxrwx 4 mpd audio 4096 Sep 29 00:28 ..
drwxr-xr-x 14 mpd audio 8192 Sep 29 00:28 data
drwxr-xr-x 2 mpd audio 8192 Sep 29 04:12 'System Volume Information'
root@runeaudio+re1:~ # ls -al /mnt/MPD/USB/RUNE/data
total 112
drwxr-xr-x 14 mpd audio 8192 Sep 29 00:28 .
drwxr-xr-x 4 mpd audio 8192 Dec 31 1969 ..
drwxr-xr-x 2 mpd audio 8192 Sep 29 11:36 addons
drwxr-xr-x 2 mpd audio 8192 Sep 29 00:28 bookmarks
drwxr-xr-x 2 mpd audio 8192 Sep 29 00:28 coverarts
drwxr-xr-x 2 mpd audio 8192 Sep 29 00:28 display
drwxr-xr-x 2 mpd audio 8192 Sep 29 00:28 gpio
drwxr-xr-x 2 mpd audio 8192 Sep 29 00:28 lyrics
drwxr-xr-x 2 mpd audio 8192 Sep 29 00:28 mpd
drwxr-xr-x 2 mpd audio 8192 Sep 29 00:28 playlists
drwxr-xr-x 2 mpd audio 8192 Sep 29 00:28 sampling
drwxr-xr-x 2 mpd audio 8192 Sep 30 09:17 system
drwxr-xr-x 2 mpd audio 8192 Sep 29 00:28 tmp
drwxr-xr-x 2 mpd audio 8192 Sep 29 00:28 webradios
Postby AndyF » 30 Sep 2019, 23:09
AndyF
Postby rern » 01 Oct 2019, 01:47
Update 20191001
- Fix - Addons update badge showed but no updates.
- Fix - Lyrics cannot be saved.
- Fix - Playlists not showed not saved.
- Fix - Bookmarks and webradio bugs.
